Upper or lower field for render? at DVinfo.net
Canon EOS Crop Sensor for HD
Old September 18th, 2014, 11:38 AM   #1
Hi all, I am just confirming a point. My material is shot on 70D, at 25fps (1080). I edit in that same timeline preset, and when exporting, i select the same settings. Field order, it IS progressive right?
When would I select the upper/lower? When going to SD, its lower? When would the upper field be used, if ever. Any advice appreciated.
Spike Spiegel is offline   Reply With Quote
Old September 18th, 2014, 01:07 PM   #2
Re: Upper or lower field for render?
Interlaced SD formats for consumer derived video such as DV or DVD are lower first whereas broadcast formats are always upper first - DV REALLY messed that up. Interlaced HD is upper first.
Progressive is none.
Old September 18th, 2014, 04:37 PM   #3
perfect, thanks Shaun
