Follow Focus lens stops..? at DVinfo.net
Canon EOS Full Frame for HD
Old March 4th, 2010, 10:21 PM   #1
I wonder if this is the only way we can add lens-stops to Canon's L lenses? ZipGear HVX200 with stop - Zacuto
-- peer
www.NoPEER.com
Old March 4th, 2010, 10:26 PM   #2
I had been looking at all kinds of solutions to this and finally decided its far easier just to use manual lenses like the Zeiss ZE or adapted Contax ones instead for times when you need proper follow focus. They are geared much better for the task too. Still use all my L lenses but not as much now with a FF.
Dan
Old March 4th, 2010, 10:43 PM   #3
Cinevate Inc.
Cinevate Inc.
These two products are great and reasonably priced.
But if you have the Durus Follow Focus you could use:
Cinevate Inc.
for hard stops.
Jason McDonald is offline   Reply With Quote
Old March 4th, 2010, 10:51 PM   #4
Originally Posted by Jason McDonald View Post
Cinevate Inc.
Cinevate Inc. These two products are great and reasonably priced.
They might be "great and reasonably priced" but I can't see how they add hard stops to an L lens. Am I missing something..?
-- peer
www.NoPEER.com
Old March 5th, 2010, 01:04 AM   #5
Dan
ZE's still don't have proper (i.e. 32 pitch) gears though. I haven't used the Contax but I think I would have heard if they did! I've used the Redrock and Zacuto versions and they are all a bit frustrating.
But yes, lenses with hard stops are much better than the free-spinners.
Charles Papert
www.charlespapert.com
Old March 5th, 2010, 08:23 AM   #6
I like the gears made by JBK: New Page 1. I have it for my Zeiss ZF and Leica R lenses.
Jerry can custom build extremely robust lens gears starting from $79.00. For hard stops, Redrock Micro also has lens gears similar to Cinevate and others. Outside of that, you may have to rely on FF units with adjustable stops.
Eric Diosay is offline   Reply With Quote
Old March 5th, 2010, 03:02 PM   #7
I'm not sure if you're looking for an alternative solution or an alternative to the HVX version you listed. I did a quick review of Zacuto's zip gears on my L lenses a while back... Zacuto Zip Gear | Paul Joy
regards
Paul.
Blog: www.pauljoy.com
Paul Joy is offline   Reply With Quote
Old March 5th, 2010, 07:30 PM   #8
Cavision rings or Chrosziel FF
http://www.bhphotovideo.com/c/product/627621-REG/Cavision_RFGR63_RFGR63_Follow_Focus_Gear.html
Cavision's follow focus gear rings, at a really really cheap price too.
"The Cavision RFGR63 is a gear ring that can be clamped onto a focus ring, allowing for the use of a follow focus system. This gear ring features TWO HARD STOPS that work with the beginning and ending focus points of the camera lens. This unit is specifically designed for the lenses between 61mm and 65mm."
(other sizes at bhphoto site)
Another option is the Chrosziel varilock follow focus:
http://www.bhphotovideo.com/c/product/665957-REG/Chrosziel_AC_206_45S_AC_206_45S_hdSLR_VariLock_Follow.htmlThere are stoppers on the follow focus itself (cant tell from pic, but its behind the follow focus turning part).
Jack Tran is offline   Reply With Quote
Old March 5th, 2010, 09:08 PM   #9
Wow, the Cavision rings are all Fuji (.6) pitch except for the largest which is 32 pitch for standard film gears. Bit of a strange choice.
Charles Papert
Old March 6th, 2010, 10:33 AM   #10
oops,
Oh wow, good catch Charles!
I figured since their FF was cine (0.8), they would sell cine rings too.
Their FF are quite solid btw, but just not well known for some reason (dont own one, but handled one)
I currently use Cinevate's ring. why not just add a zip tie or gaffers tape (same as adding a stopper).
Old March 6th, 2010, 01:51 PM   #11
-- peer
Does anybody know where you can get those stops with out buying the gears? I already have lens gears and now need the stops.
Red Epic available for rent, starting at $500 per day, Scarlets, and Lenses available too. rentals.maddalenamedia.com
Louis Maddalena is offline   Reply
