Magic Lantern & HDMI Output at DVinfo.net
Canon EOS Full Frame for HD
Old November 30th, 2012, 02:15 PM   #1
Hello,
I have been checking out Magic Lantern for the MKIII and wanted to ask a question about HDMI output. I thought I had read that ML had found a way to output an HD signal over HDMI?
I do not need to record the signal at this time but it would be great for monitoring on my Small HD DP1x 720p monitor. Right now the signal from the camera has the large black areas around the video.
Is there any way yet to get the video full screen & HD?
Old December 3rd, 2012, 09:25 AM   #2
Re: Magic Lantern & HDMI Output
Check your firmware for the monitor... I know that on my DP6, they released a new firmware about a year ago that had a special preset for DSLR (both Canon and Nikon) to be able to view the image full screen.
In this mode, some of the OSD is cut off such as histogram, but you do get a nice full-screen image.
Don't know if they did this for your monitor or not... seems like they would have. Not familiar with the DP1 or I would have included a link to the firmware for you.
Good luck!
John Carroll is offline   Reply With Quote
Old December 3rd, 2012, 08:56 PM   #3
Thanks John. So it is monitor issue? I had thought the MKIII was supposed to output a fullscreen image. I should try to hook it up to a television and see it if it shows fullscreen.
Will go to SmallHD's website and have a look.
Old December 4th, 2012, 08:34 AM   #4
Sure thing!
If you plug directly into a HD monitor, it will fit the screen properly... the built in LCD is a different shape (not 16:9) since it displays the HD image as well as OSD data. The odd shape makes it possible to show some of the OSD slightly offscreen so it looks a little less cluttered. Probably not designed that way but more of a happy accident.
Old December 5th, 2012, 09:06 AM   #5
Press the Info button on the 5D3 while plugged-into and HDMI source and it rotates through the various screen overlay options. One option will remove all of the OSD info and zoom up the image quite a bit.
My DP6 has a function to move the display around x and y, and does a fair amount of zooming, too. Perhaps the DP1 does this, as well.
Brian Brown is offline   Reply With Quote
Old December 5th, 2012, 05:57 PM   #6
Thanks. I will give that a try.
Old December 5th, 2012, 08:34 PM   #7
Brian- Does your DP6 have the DSLR preset? If not you should download the firmware... sure makes it easy!
Old December 9th, 2012, 10:40 AM   #8
Update. Pressing the INFO button enlarged the image, not filling the entire monitor, but a lot better. Thanks for the tip.
Old December 12th, 2012, 01:59 PM   #9
using the DSLR preset (if available) will fill the frame on the horizontal axis completely.
