GL2 Power Off - Any Updates? at DVinfo.net
Old May 11th, 2008, 10:11 PM   #1
Found a year-old post about a GL2 that powers off while in use then restarts itself shortly. We have a camera which has just started doing this while powered through the electrical cable. The camera's only used in a stationary indoor setting. Any new info on what might be causing this problem - and possible solutions?
Teresa Brown is offline   Reply With Quote
Old May 14th, 2008, 10:53 PM   #2
Does it do this with the battery attached?
Black Label Films
www.blacklabelweddingfilms.com
Travis Cossel is offline   Reply With Quote
Old May 26th, 2008, 12:31 PM   #3
This particular camera is used in a stationery position with electrical plug-in for IMAG, so never on a battery.
Old May 26th, 2008, 10:37 PM   #4
You might want to experiment and see if this happens with a battery as well. Might help with the trouble-shooting.
Black Label Films
