HELP! Cannot plug the LANC cable! at DVinfo.net
Old May 16th, 2004, 12:27 PM   #1
I have my xm2 finally.
But..
I cannot plug fully the 2.5 stereo mini jack to the LANC connector.
(our homemade zoom controller)
With Sony's D8 this wasn't a problem.
The documentation says, this is a standard LANC connector.
Is there any difference between a 2.5stereo mini jack and a 2.5stereo mini jack??
Should i use a mono jack? But we need the power too!
Prech Marton is offline   Reply With Quote
Old May 16th, 2004, 03:10 PM   #2
Retired DV Info Net Almunus
I am confused.
Are you saying that you've built your own LANC controller using a stereo mini-plug?
Old May 16th, 2004, 10:53 PM   #3
Yes, it's not a hard work.
Just some precise timing, and we know the codes for variable zoom, manual focus, etc.
http://www.boehmel.de/lanc.htm
BUT I CANNOT PLUG IN!!
Old May 16th, 2004, 11:10 PM   #4
Here is my beauty:
http://web.axelero.hu/prechj/pics/lanc-zoom.jpg
Old May 16th, 2004, 11:15 PM   #5
Old Boot
Excellent LANC INfo!
Prech! Excellent fundamental activity. I know this will be of great use to the technicians out there .. very intereting . .. I DO like your table of LANC functions . .very good indeed!
No, I can't help you out with the LANC diam - but many thanks for sharing,
Grazie
Old May 16th, 2004, 11:54 PM   #6
Re: Excellent LANC INfo!
And here is the problem:
web.axelero.hu/prechj/pics/lancproblem1.jpg
web.axelero.hu/prechj/pics/lancproblem2.jpg
i don't want make more force, because my cam is very new, and
don't want broken the plug into my cam :(
So, i think this is a standard 2.5mm stereo mini jack:
web.axelero.hu/prechj/pics/lancproblem3.jpg
i will call Canon soon
Old May 17th, 2004, 12:55 AM   #7
Re: Re: Excellent LANC INfo!
Good News!
My problem is solved!
With a grater i have lower a bit the thickness of the jack.
It seems, here in Hungary, standard is not a standard.. :)
thank you
