OT: Need 6mm to ¼" Whitworth? at DVinfo.net
Old July 11th, 2004, 03:56 PM   #1
Old Boot
[Ken . .usual request to move where you want to .. thank you .. Graham]
Says it all.
It's for my new external 5" LCD monitor for filming. I can make a bracket . . but would like to convert exsisting 6mm threaded hole to ¼" Whitworth. Not much option to Tapping it . . .
TIA
Grazie
Old July 12th, 2004, 02:50 AM   #2
Get a small piece of 6mm aluminium sheet (or 2x3mm sandwiched together) with Araldite. Drill one hole for 6mm bolt to fix to base of monitor and a second nearby tapped 1/4" Whitworth.
Expensive if you don't have the taps and dies (try Screwfix for these); 3mm Aluminium is available in B&Q.
Alan Craven is offline   Reply With Quote
Old July 12th, 2004, 03:05 AM   #3
Old Boot
Alan . .you been following me?!?!?! "3mm Aluminium is available in B&Q." . . I was there yesterday! and yes, this is exactly the solution I've come up with. I'm gonna use a nice piece of angled ali [ B&Q ] that will cover the 6mm, drill hole for the ¼" WW and go from there.
As a test I got a 48p - yes 48 pence - fence wooden strap "U" fitting from B&Q .. galvanised bent metal. Might use this instead!
Alan thank you,
Grazie
Graham Bernard is offline   Reply
