Confusing the LCD at DVinfo.net
Old November 2nd, 2004, 09:32 AM   #1
Confusing the LCD
Hello everyone!
Only a short question:
Is there any possibility to make my GL 2 think the display is flipped 180° without having it flipped? (the picure shall appear upsidedown, and be mirrored... )
I saw a picture on the internet, a guy did this with his Sony PD100A and ... nails ...
"The nail attached to two blocks of plastic is depressing a little internal switch which makes the monitor flip its image."
Has anybody got an idea how I can achieve this with my GL2 ?
Thanks a lot,
Maxi.
Maxi Zenk is offline   Reply With Quote
Old November 2nd, 2004, 10:47 AM   #2
The GL2/XM2 has a litle magnet on the camera under the LCD hinge. There's a senzor on the LCD, above the hinge.
The litle magnet can be removed - it is under a small covering. I removed it and placed it near the senzor on the LCD and that turned the image while the LCD was in the normal position.
Others taped a litle magnet on the LCD, at the senzor area.
You're probably trying a mini35 DIY? :)
Cosmin Rotaru
Cosmin Rotaru is offline   Reply With Quote
Old November 2nd, 2004, 03:48 PM   #3
Hey Cosmin!
What you said is fact, it's for a mini35 :)
Thank you very much for your hint, I'll have a try wirg a 2nd magnet tomorrow.
Removing the magnet makes my gurantee invalid, right?
Maxi.
Old November 3rd, 2004, 10:34 AM   #4
"Removing the magnet makes my gurantee invalid, right?"
I can't see any seal in there... I put it back and you can't tell its been off.
Cosmin Rotaru
