#271 |
EW112P and MA 200 not working
I got my EW112p over the weekend and couldn't make it work with MA 200. It works fine with the mini jack.
I read both manuals and believed I got all the cables the right way: Audio 1, MIC input, etc. The only thing I can think of is that when I ordered the XLR cable CL100, they told me it was out of stock and recommended me a KORDEX cable instead. Maybe only the CL100 cable works with EW112p? Please help me solve this problem. Thanks.
TZ |
#272 |
GL2 or XL1?
Please be more precise about your cable routing and switch and menu settings? |
#273 |
Retired DV Info Net Almunus
Can you be more specific concerning "NP" batteries? The Canon BP series batteries (and compatibles) produce 7.2v.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#274 |
Don. thanks for your reply. I called Sennheiser yesterday and they told me that their XLR cable is wired differently than other companies'. I am going to return the KORDEX cable to MVP Audio and Video from whom I got the not very helpful recommendation. I hope the system will work after I get Sennheiser's CL100 cable. I'll let you know.
TZ |
#275 |
Motor Sport
Hi
I'm a bit of a XM2 newbie and need some advice on camera settings when videoing motor sport events and similar. I've done some work with JetSki racing with a Sony PC100 which I also own, but only in auto mode and have been more than happy with the results when burnt to DVD via Prem 6.5, Matrox RT.X100 & Sonic DVDit SE. I recorded some gokart racing at the weekend with my new XM2, mounted on a tripod and in grown-up (Manual) mode. Manual focus & Zebra stripes were turned on. I only adjusted the aperture settings leaving the shutter & gain settings alone. Back home and into Premiere. The results didn't look too good. All panned and action shots looked a bit blurred. Anyway, burn DVD @ 8mbs CBR and check out on big screen - argh - awful, looks like every driver is wearing 2 crash helmets or worse. I guess maybe I should have gone for the 'Tv' mode and changed the shutter speed - but I'm not too sure - the're too many buttons to press on this cam and the viewfinder doesn't make these problems easy to spot. So help - any suggestions as a good starting point for cam settings for this type of vid? Also searching thru this forum I see that OIS should be turned off when using a tripod - would this have made any difference? Thanks for any help Adrian |
#276 |
You shoot in Frame mode?
I prefer the normal mode (interlaced), Shutter 1/50. Then I de-interlace in software. Stay in Manual, leave Gain to 0dB. You can use an additionnal Neutral Filter (small aperture tends to blur a little the image), I have a B&W 102 (2 stops). Set the Zebra to 100% and don't over expose (You can over expose the sky, but never the subject). You can leave the OIS on all the time. It is optical, not electronic. |
#277 |
Contributor
Wireless Mic Receiver Attached to GL-1?
I had such good luck with the recent question about my shotgun mike that I thought I'd try one about my wireless. I have a Samson UM1 UHF Series One receiver that I'd like to mount someplace on my GL-1, particularly during interview situations, both on and off the tripod. This is the same wireless receiver that the manufacturer pictures mounted on the tape access door of the XL-1 in all of its magazine ads. Is anybody doing this with the same or a comparable wireless, or is the camera just too small. Any ideas on how or where to mount it? The unit and its Sony ECM-44 lav works great for interviews and I'd like to use it with the GL.
#278 |
Jim,
I have a mount that does just what you are describing that I use with my GL2. Had to have it fabricated because I couldn't find anything that would work well. Let me know offline if you would like photos/info. |
#279 |
XM2 Still Picture Quality
Hi Guys
I have recently bought an XM2 (I live in Australia) and found that the still pictures look like there's a slight solarization effect applied to them. I am using fine mode, high quality. Has anyone else come across this? Thanks heaps Tim |
#280 |
GL2 in auto mode
In the auto mode the GL2 could be better for daytime video. I have seen this more often than not. Check the last 2 pics here:
http://homepage.mac.com/bhardy3/PhotoAlbum34.html I have not included a frame in sunlight mode yet but intend to, as I am very impressed with the video in sunlight setting. Too bad it's raining today... |
#281 |
High School Student
Yeah. It appears that the 2nd one is just saturated more. Still looks better though.
#282 |
camera mounted mic receiver
I use an azden wireless lav mic receiver that has an accessary shoe attatchment on it. It works out quite nicely as I don't have to worry about trailling cords, and it runs off a 9v battery. Now I do still have to use a 1/4' - 1/4' (or is it " for inch?) cord to the mic in on the camera, but that is a small worry. This set up works wonderfully for recording wedding audio with my gl2, and even better with the 4 channel audio of the XL-1. Hope that was what you were talking about.
Jesse |
#283 |
Capt. Quirk
I'm with Jesse on this. I have the same setup, azden wr-22 and a GL1. On the few occasions I recorded the audio into the cam, this was how I did it. I'm sure there is an accessory shoe attatchment for your reciever.
#284 |
Little clip I made today...
Just messing around in Premiere and made this. Tell me what you think.
http://www.visital.com/random/catseye.mov Ryan Krga |
#285 |
I will explain it when I get back, sort of in a rush right now, sorry.
| Thread Tools | Search this Thread |
