GL2 white balance? - Page 2 at DVinfo.net
Old April 18th, 2007, 02:51 AM   #16
If you still get too much green after manually white balancing, you could turn down the green a little bit in the custom preset.
Old April 18th, 2007, 07:57 AM   #17
Thanks for your suggestion. I have tried that but it doesn't compensate enough. I have to try different white papers I think, or in worst case check my camera at Canon service center.
How about you guys? Do you have success with manually WB indoors?
Cheers
/Ronnie
Ronnie Lindqvist is offline   Reply With Quote
Old April 20th, 2007, 07:24 AM   #18
Location: Central North Carolina (Raleigh, Durham, & surrounding areas)
Originally Posted by Joe Irvine View Post
After a manually set white balance do you need to reset WB after taking the camara into Lock and bringing it back to Standby? Also the same question with reguard to a auto power shut off.
Thanks in advance joe irvine
Simple answers, No and No. It's been my experience that the manual WB maintains it's settings even when you remove/change the battery. I'm assuming it's due to the internal battery.
Mark
Mark Holland is offline   Reply
