best teleconverter for GL2? - Page 2 at DVinfo.net
Old June 26th, 2006, 11:21 AM   #16
i apologize for any perceived attacks on my part.
here's a link which you might find helpful.
http://www.dvinfo.net/conf/showthrea...+teleconverter
Old June 26th, 2006, 01:59 PM   #17
I have used several teleconvertors, but strongly recommend the Century Precision Optics 58 mm 2x convertor mentioned above. Yes, it costs around $ 400 new as I remember, but it is optically very good, and you can use adaptor rings to use it on other cameras. I got mine from B & H several years ago and have had excellent results.
Mark Donnell is offline   Reply With Quote
Old June 26th, 2006, 05:54 PM   #18
Meryem,
that is the thread that I found on a search that made me decide to ask the question again, since there was no definitive answer, the first TC was never identified (even after I referenced the original thread), and the topic strayed into sony converters, FX1's, 1.6's, 1.7's, back and forth to see links to pretty pictures, chats about visiting each other, etc., and finally, one of YOUR responses which led me to recommend the Century.
If Grazie or you had opined for the CO 2X in the first place then none of this egotizing would have occured, and ignoramouses like jersey jim would have had to find other threads to misinterpret.
ALERT!!! GASEOUS AND BLUSTERY RESPONSES TO FOLLOW, CONDITION NOT LIKELY TO IMPROVE, PROCEED WITH CAUTION.
Jeffry Alan is offline   Reply With Quote
Old June 26th, 2006, 08:33 PM   #19
EDIT: nevermind. But chill out, Jeffry. Jeez.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old June 26th, 2006, 10:35 PM   #20
dude, sorry the ALERT didn't warn you from continuing this unnecessary and obsequious dialogue, but if you didn't happen to notice it, I answered my own question, like, 12 posts ago. But I am glad that I caused you to edit your initial vitriolic response, so as not to look like you took the bait too hard.
So go home, or go to sleep, or whatever you do in Chatanooga, but let it go man, this convo is ended, and I have work to do.
J*
END OF TRANSMISSION
