strife trailer gl2 at DVinfo.net
Old August 1st, 2006, 09:40 PM   #1
strife trailer gl2
Hey all,
Here is the link to the trailer for my feature film shoot on a GL2. Tell me your thoughts??
http://www.youtube.com/watch?v=Pvui9CCtyE4[/url]
Tunde Anjorin is offline   Reply With Quote
Old August 2nd, 2006, 12:17 AM   #2
Really good but needs some 25fps to 24fps to give it a film like
Nathaniel McInnes is offline   Reply With Quote
Old August 2nd, 2006, 04:29 PM   #3
How do you do that on a GL2?
Alex Sprinkle is offline   Reply With Quote
Old August 2nd, 2006, 04:36 PM   #4
You can't. You can approximate the look of 30p with frame mode, or you can try to deinterlace in post. But neither of these things will produce the same results that a camera with true progressive chips will.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old August 2nd, 2006, 09:19 PM   #5
Thanks for the comment Nate! Care to expatiate on “really good”; I’m really not worried about the frame rate for now…
Old August 3rd, 2006, 04:07 AM   #6
simple i use final cut pro and it gives me a option to take 25fps to 24fps. You would be amazed to see the difference. After that put it onto a dvd play it on a 5.1 surround system and u will be amazed by the difference. it feels more like a film.
Old August 11th, 2006, 09:02 PM   #7
i liked it.
it did look like 24p
you need to use like a movie look via magic bullet,it would make a big difference
Nate Fields is offline   Reply
