Premiere Pro 2 Import Settings For HV10 at DVinfo.net
Old February 10th, 2007, 03:18 PM   #1
Hi,
is anyone seeing the preview when importing from HV10 into PP? I'm still not sure which camera type I should choose inside PP2 - There is still no official support for hv10 :-(
Which settings do you use?
thx
Helge Schneider is offline   Reply With Quote
Old February 10th, 2007, 03:29 PM   #2
Just look for an option that says HDV 1080 60i and you should be fine.
Paulo Teixeira is offline   Reply With Quote
Old February 10th, 2007, 03:36 PM   #3
in my PP there is no such option.
Old February 10th, 2007, 03:42 PM   #4
I think you mean device control, not camera. That should be DV/HDV device control, or at least that works for my XLH1. And, you will not see the preview unless it is on your camera I believe.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old February 10th, 2007, 04:43 PM   #5
sorry. Yes I meant device control.
At least there is no specific for the HV10 available. I tried several others without a real success (on Windows Vista) - sometimes I'm able to control the device (play, stop, fast fwd, rewind) but not able to record. And I can't get the preview window working anymore.
As far as I can remember it worked at least sometimes on PP2 when I had it on a XP system ...
Old February 10th, 2007, 05:07 PM   #6
No preview window in PPro2 with the HD footage, it previews on the camera viewfinder. Just set the device control to the DV/DHV setting. Should work fine. That is unless you run out of battery, which I just did!!!!! DUH!!! Now I have to recapture a whole tape.
Mike
