16 minute clips at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old December 3rd, 2011, 01:35 PM   #1
16 minute clips
I recorded about 2 hours of video at third highest video quality setting. I recorded on a 32GB SDHC card @ 20MB/s. When I view the video it breaks it up into 16:22 clips. Why did it do this? And can It just record a straight 2 hours without the clips?
Jamie
It's a Canon vixia hf41
Jamie Walker is offline   Reply With Quote
Old December 3rd, 2011, 02:03 PM   #2
Re: 16 minute clips
I may have my answer in another post...
http://www.dvinfo.net/forum/canon-xa...-problems.html
Old December 4th, 2011, 06:01 AM   #3
Re: 16 minute clips
Right, it's the file size.
Old December 4th, 2011, 06:27 AM   #4
Re: 16 minute clips
As I understand it, the split (at ~2 GB) is in part due to the file size limitations of the file system used on the SD cards and in part legacy from the old Microsoft type 1 AVI file limitation days. FAT 32 commonly used on memory cards actually has a 4 GB file size limit, but Type 1 AVI files were limited to 2 GB. Most makers of AVCHD gear still stick to the 2 GB file size limitation - perhaps to reduce the incidence of issues with other connections to other gear; e.g., people trying to copy a large file to a smaller storage device.
The old command line function: COPY with the /B option can be used to assemble the piececs into one big file with no "missing" frames on a NTFS drive if you do not have the necessary utility on hand.
dpalomaki@dspalomaki.com
Old December 5th, 2011, 05:16 AM   #5
Re: 16 minute clips
Thanks for the replies. I appreciate the help.
Jamie
Old December 5th, 2011, 06:26 AM   #6
Re: 16 minute clips
i also posted this in the thread linked a few posts up:
i use this free program here: MTS File Joiner
it joins the files in seconds with no recompression. It was actually made for Vixia users, works like a charm.
Iker Riera is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
