Audio confusion at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old September 6th, 2012, 08:06 PM   #1
Audio confusion
First test with new XA-10...
After recording a session where a speaker was talking to a small group, I downloaded the .mts files and imported them into my NLE program (Premiere Pro). However, although the video clips play fine in Premiere, I can hear no audio. Soundtrack seems to be there, the volume meter acts normal, but no sound. Same playing in Windows Media Player.
We were using a shotgun mic connected to XLR connected to CH1 and monitoring w/ headsets and throughout it seemed to be working fine. if I plug a headset into the cam and play back the videos, the sound is fine.
Not sure where to start looking for how i messed up??
Tim Ribich is offline   Reply With Quote
Old September 6th, 2012, 08:43 PM   #2
Re: Audio confusion
If you hear audio in the camera, your issue sounds like a post production issue with PP. Consider posting in the PP forum for some ideas also.
Old September 6th, 2012, 09:08 PM   #3
Re: Audio confusion
Thanks Jeff-- but since posting I managed to figure it out.
Turned out to be one of those DUH! moments. I had moved some gear around before I left for the shoot and when I reconnected things after i got back, somehow the computer speaker got connected to the wrong audio input. Online videos played fine with good audio which caused me to overlook the obvious.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
