#16 | |
Re: XA-20 is a fine camera
www.tubeshooter.co.uk www.youtube.com/ukairscape and www.youtube.com/tubeshootermag Last edited by David Johns; July 16th, 2013 at 06:09 AM. Reason: Added comparison note |
#17 |
I had a chance to use one for a week of wildlife photography (seabirds). Some notes -
PROS - The 20x is brilliant. For some reason, even on my XH-A1 when I brought the footage into FCP it would go to 1440x1080, so having full HD at 50p (I have the PAL version) is absolutely brilliant. Incredible footage. The image stabilization is far better than anything I have ever used before (but there may be an issue with power image stabilization, see below) The 2x digital tele-converter is useful. What I am not sure of yet (but will be checking in the next week) is whether the same thing can be obtained by cropping in post. There is some image degradation (and possible vignetting, oddly enough, see below) but it certainly does not degrade down to SD or worse. I used a Sony 1.7x teleconverter and it worked fine. I tried it with the 1.7x lens setting (supposed to tell the camera to modify the IS and AF) and without and am not sure I noticed a difference (maybe only works with the Canon lens). The image was slightly softer at full zoom. I have not been able to try my old Century Optics 2x teleconverter as the bayonet mount for the GL1/2 (which the lens was designed for) and the XA-20 are different. Anyone know where I can get some sort of ring to take my old Century Optics bayonet mounts and make them 58mm? I also tried the 1.7x + the 2x digital. Again, the image was softer but useable. I will try and post some images next week. Battery life is decent on the stock battery. It took an extra week or so to get a second battery so I had to be battery frugal on this trip. The focus assist is very nice, especially on birds in flight, to see what the camera thinks it is focusing on. AF is fast and generally accurate, I noticed very little hunting CONS - Battery charges ON the camera rather than OFF the camera. Charging batteries off of the camera requires a separate charger. The obvious position for holding the camera (at least for me) without the handle on, means that one or more of my fingers rest on the left microphone. I will learn to work around this. A MAJOR drawback is the power off feature (or lack of one). WIth the XH-A1, GL1 and GL2 there was an on/off switch around the start button. In some of my other cameras closing the LCD and pushing in the viewfinder also turns off the camera until one of the two is open. NOT THE XA-20! Even with the LCD and viewfinders closed pressing the start button will start the camera. Not good to lose a lot of battery life filming the inside of the camera bag. So, each time the camera is used the main camera - off - media switch has to be turned on or off. There are also some odd artifacts in some of the footage. A faint darkening will occur in the top left and right when fully zoomed in. This looks a bit like vignetting (although not entirely). What I am not sure of is whether this is only with the 2.0 digital zoom on, or if it is also occurring on optical zoom only. Also, whether it might be an artifact caused by the power image stabilization. As the artifact is only on some images I suspect it is one or the other, and am leaning toward the power IS or the power IS with digital zoom. The programmable buttons are not that useful as they are currently programmed. For example, say you want to program a button for the 2.0x digital zoom? You can't, or at least I couldn't figure it out. You can program to go to the zoom menu, but then have to use the touch screen or toggle to go to the 2x zoom on/off. Same is true for many of the other controls. Perhaps a future software upgrade will allow better programming of the buttons to exact menu items. Finally, the manual suggests there is an IS button. This would be handy to turn power IS off and on but I can't find this button if there is one! My overall first impressions were good. I'll let you know about second impressions when I have the chance to fully go through the footage shot. |
#18 | |
I had pre-ordered the XA20 but cancelled it to wait for a few real world reviews first. Getting closer every day to re-ordering this unit now. |
#19 |
The digital IS is not the same. The (only) problem with the XA10 etc 2073600 px sensor was that it didn't allow any leeway (extra pixels at the edges) for digital IS. The sensor in the G20/25/XA20 fixes this.
#20 |
That new IS is impressive better than the XA10
thanks for posting Luis |
#21 | |
I hope to perform some tests this weekend where I pay more attention as to which setting is on |
#22 | |
It does not have the extra pixels that the newer camcorders do, to assist with stabilisation. Regards
www.tubeshooter.co.uk www.youtube.com/ukairscape and www.youtube.com/tubeshootermag |
#23 |
Digital zoom typically forms the image from a smaller (cropped) central portion of the sensor. It essentailly upscales the cropped image to full frame. It should be less subject to any vignetting caused by the lens because it uses the sweep spot in the center, but results in lower resolution than the full frame of the sensor.
Digital IS typically works in one of several ways. It may shift the portion of an oversized sensor used to form the image as a way to compensate for camcorder movement, it may upscale the frame-sized sensor to form a larger virtual image and then shift the portion it uses to form the image, or it may shift the image on a frame-sized sensor and extrapolate the edge in the direction of the shift. These all could give more obvious vignetting effects. The second two would usually result in some image softening. Also image settings (e.g., gamma curve adjustment) could exagurate vignetting effects, especially at the limits of lighting conditions and subject matter. Nothing like shooting a flat white wall in auto exposure mode with poor light to demonstrate this.
dpalomaki@dspalomaki.com |
#24 |
Yes. I just got confirmation through Canon USA's website tech. support forms -- Canon replied saying that the only thing you get for the extra money of the XA-25 over the XA-20 is the HD-SDI port.
#25 | |
HF G10 Sensor: 2.37 Megapixels HF G20 Sensor: 2.37 Megaxpixels HF G30 Sensor: 3.09 Megapixels XA10 Sensor: 2.37 Megapixels XA20 Sensor: 3.09 Megapixels Source: Canon U.S.A. : Support & Drivers : VIXIA HF G10 Canon U.S.A. : Consumer & Home Office : Consumer Camcorders Canon U.S.A. : Support & Drivers : XA10 Canon U.S.A. : Support & Drivers : XA20 |
#26 |
This camera looks real interesting. There's not much info on the nd filters that I can find (haven't looked through the manual yet) so are the nd filters user select-able or integrated?
Tim |
#27 |
Here are 2 tests of the Xa25 vs the GH3:
#28 |
Hi,
how you judge the the test against the GH3? Probably are my faulty eyes but i find the Xa-25 at the same level of the Gh3. Ok adding exposure filter in FCP rise up noise but also the gh3 isn't free... and remember we are comparing the xa-25 with a DSLR (bigger sensor). Also I can read at 0:05 the "taxi" word better on the xa25 Ugo |
#29 |
In my opinion, the above videos are worthless as comparison videos without knowing the lenses used on the GH3, but more importantly it's apples to oranges. They are mildly interesting, but beyond that, not awfully enlightening.
Nevertheless, I do appreciate anyone who take the time to post video such as these, but in this case I don't see a lot of benefit. Anyone who has both cameras knows these are not comparable. 1/3 inch sensor vs a nearly 1" sensor is not in the same ballpark. I have shot with two GH2s and two XA-10s for dozens of weddings, receptions, and corporate shoots. The cameras blend very well in certain situations, particularly in churches. That, however, is where most of the comparability ends. I have seen the XA-10 produce images I like better than the GH2 in a situation or two. But more often than not, the GH2 has more to offer in image quality. The increased dynamic range of the GH2s and GH3s alone put it in a higher bracket than the XA10-20-25. And lest we forget, things often depend on the lighting more than the camera anyway. As has been said by wiser men than me, these are tools, nothing more. You use the tool you need for the job it is best suited for. |
#30 |
I've just come back from Slovenia and I have to say this is a very impressive camera for wildlife. Oddly enough the vignetting did not re-occur so I am going to have to do some real sleuthing to figure out what it might have been (it might be something as simple as the built in lens cap sagging under certain conditions).
The footage out of this camera easily tops most of the footage out of my XH-A1. I only wish this camera was available a year ago (or two)! |
