Setting the Camcorder's WiFi Password at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old January 20th, 2014, 08:18 AM   #1
I have been trying to set my XA20 camcorder's password for a WiFi connection, but when I follow all the recomendations in the manual, I do not get the aphabetical display of the virtual keyboard, only the numerical display appears. Have I missed something?
Jo Ouwejan is offline   Reply With Quote
Old January 20th, 2014, 02:42 PM   #2
Re: Setting the Camcorder's WiFi Password
If you are trying to connect to a “smartphone connection” (first option on the Wi-Fi menu list) you only need a numeric password so you only get the numeric keyboard.
On the other hand if you are trying to connect to a Wi-Fi network or “Access Point Connection” (second option on the Wi-Fi menu list) you will get a alphanumeric keyboard.
Hope this helps
Ross
Ross Williams is offline   Reply With Quote
Old January 20th, 2014, 02:49 PM   #3
Ah, I see! I was thinking I had to create a new 8-digit password, but the 4-digit pincode looks logic.
Thank you, Ross, I will try tomorrow.
Old January 21st, 2014, 11:18 AM   #4
Tried that, but did only work, after I effectively placed an 8-digit password/number.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
