#16 |
Re: Canon HF G30 Cinema Mode
That's the one Don!
One display in particular shows bad banding, on the laptop I bought for editing a few months ago. A display I hooked to it shows a touch of it on one clip (raw camera clips), the display on the other laptop, which is not for video although capable, doesn't show it on any of the clips. A transcode of a few clips didn't improve things, neither did any driver settings. So not entirely Cinema Mode then! One problem solved and another one to consider. The idea of a laptop for editing rather than a new desktop is so I can do some editing while away from home, but it certainly won't be much fun like that. I don't see it as a warranty claim, it hasn't broken, so I'm stuck with it as it is for now. Thanks Don, I hadn't considered the display. Why would I, it's a new top of the range laptop? I have bookmarked the links for an in-depth read later. |
#17 |
Glad you solved it. And there was me seeing if I had any Cinema Mode footage from my old HV30 or HV20 archived somewhere - which I don't, but I seem to recall there was an issue there with posterization on fine gradients, not too mention increased noise in the shadows. There again it could have been my monitor ;-)
#18 |
Cheers Bryan.
It looks like I shall be trying another Linux distro on that laptop, the other (good display) one has a different distro. It could be that simple. If not, I shall have to swap them over. |
#19 |
been out today with the g40 and had no problems with the zoom bit strange to say the least!!!!!
Ian Thomas. Thomas Video Productions |
#20 |
Update for Don and Bryan
It isn't the display, it's the driver. I booted a live distro and the offending clips played beautifully, so I installed it, still good and I'm now putting all my stuff on it. It's a relief it's only one machine! At least I now know I can use Cinema Mode on my G30 if and when I like. Thanks again gents. |
#21 | |
dpalomaki@dspalomaki.com |
#22 | |
That would make a good bumper sticker..........for the wife that is :‑o Right - I noticed it a bit in Cinema Mode on the HF-G10 also, but it's much cleaner on the HF-G30. Didn't check out Cinema Mode on the HF-G40 but increased shadow noise was one of the things I didn't like about Wide DR mode. Seemed to be pushing the gain/noise floor dynamics to the limits. Last edited by Bryan Worsley; April 7th, 2018 at 12:53 PM. |
#23 | |
I'm not so bothered about noise in the shadows and it's not just shadows, the whole image is noisier than MM, but a little denoiser can work wonders, depending on how bad it is of course. I proved it was the Nvidia proprietary driver by installing it and getting the banding back, but it won't go away just by uninstalling. I'm sorting that out now. For the record, I will post the details when I've finished in case anyone else has a similar problem. |
#24 | |
I've tried everything else.
If conspicuous noise is confined to the shadows, I'd be more inclined to treat it selectively with a mask. If it's in the highlights, I'd look at the trade-off. Last edited by Bryan Worsley; April 7th, 2018 at 01:05 PM. |
#25 |
Noise is easier to notice/see in shadows. Two IRE units of noise fuzz on a 10 IRE image is 20%, while the same 2 IRE units of fuzz on an 80 IRE signal is only 2.5% and less obvious to the eye.
#26 |
#27 |
As a quick test using an XA20 I shot video of the 6 gray blocks on a Macbeth Color Checker Chart in Manual and in Cinema modes. I set the brightest white (90% reflectance) square just into 100% Zebra (set to I00 IRE). Shutter was 1/30, aperture about F/4.0 adjusted to provide zebra, with 12 dB gain, halogen light.
The attached chart below shows the resulting IRE levels of the six gray squares for each mode. It is apparent that Cinema allocates lot more IRE range/space for shadows with under 3% reflectance.
#28 |
Interesting. You can also make that out in those fuzzy waveform plots I posted earlier - the Cinema Mode curve has that upturn at the bottom end - what would you call that in terms of gamma curve 'anatomy' - "toe-stretch" or something ?
#29 |
That noise comparison is interesting, thanks Don.
For the record: I do not have the make/model of the laptop display, but the machine itself is a StationX Lancaster, the 15.6" display is matte, 1920 x 1080 IPS. The graphics card is NVIDIA GP 106M (Geforce GTX 1060 Mobile 6GB) The driver is the Video-Nvidia proprietary Linux driver. To reiterate, banding in certain video clips showed up badly when the Nvidia proprietary driver was installed, but not without. Simply uninstalling the driver did not stop the banding. The OS was Manjaro KDE, but I found the same effect with other distros. A re-installed Manjaro without the driver does not have the problem and I have disabled the card in BIOS. Just to make life more interesting, my backup drive had suddenly become read-only and unmountable, so I have just spent several hours attempting to recover the files. A success thankfully, good old Puppy Linux, I always keep a copy on hand just in case! |
#30 |
[Quote]...what would you call that in terms of gamma curve 'anatomy' - "toe-stretch"...{/Quote]
Here is how Canon describes it in the XHA1 manual. Black, knee and gamma all interact. As to why the banding it is more apparent in Laptops, I suspect that in the interest of saving power they try do things in the least processing intensive way, and use displays that draw less power. The additional processing to do a full 8-bit or dithering is not necessary for most purposes, so they save a bit of power by doing 7- or 6-bit and skip on the dithereing. Then banding can become apparent under certain image circumstances. Changing drivers and/or firmware may adjust this, but at a power consumption cost. I wonder if just uninstalling the drive did not effect it because the drive installation may have included a firmware update. I know that happens with the BlackMagic Design Intensity cards.
