SmallHD DP6 - Un-Support message at DVinfo.net
Old January 16th, 2012, 01:26 PM   #1
I am trying to connect XF300 to DP6 monitor via HDMI and the blue screen simply says "Un-Support"
Any ideas? Some setting somewhere?
Harry Pallenberg is offline   Reply With Quote
Old January 16th, 2012, 04:14 PM   #2
Re: SmallHD DP6 - Un-Support message
While I can't be too much help in solving your problem, I can at least say I use a DP6 with an XF300 all the time, so the combination is fine.
I did see that message just once, a couple of months back after installing the new DP6 firmware. I played with DP6 settings to get it working: can't remember exactly what I'm afraid, but I recall it only took a few seconds and it wasn't the XF at fault.
The DP6 is hugely beneficial with the XF - even at 4" I find the XF screen tough going.
Josh Dahlberg is offline   Reply With Quote
Old January 16th, 2012, 10:21 PM   #3
Give out support team a shout. They should be able to help. Website link or support@smallhd.com.
-reed
Reed Phillips
www.SmallHD.com
Reed Phillips is offline   Reply With Quote
Old January 16th, 2012, 11:01 PM   #4
I talked to support & posted elsewhere. In the end changing the preset from 1 to 2 seems to have 'fixed' it.
Not sure how or why - but I get the picture.
