Shotgun Mic?
I just ordered this kit and wondering if it is a good choice for the XH A1. I didn't do much checking, and if its not a good setup can exchange it.
http://www.bhphotovideo.com/c/produc...oid_Short.html Thanks |
Contributor
That's a decent mic for the money. I see they give you a shock mount; you'll need a boom pole too and some cables.
Thanks, I will pick those up too.
Just because this forum is already open... i thought id just ask if anyone has used the Azden 2X?
http://www.azdencorp.com/shop/custom...roductid=93299
Loren Simons |
#5 |
The Sennheiser ME66/K6 combo is a good shotgun mic for video.
I would not suggest the Azden for serious video use for the following reasons: Compared to other short shotguns in the same general price range; e.g., the AT-897 or Rode NGT-2, the Azden has: Higher output impedance ( ~2x) Poorer signal to noise ratio (~ 7 dB) 1% distortion at a substantially lower sound pressure level (~5-15 dB depending on power source) Less dynamic range, (~13-27 dB) does not appear to support phantom power and I suspect that the Omni capsule would be of limited use for video. But it is somewhat cheaper, and might meet your needs.
dpalomaki@dspalomaki.com |
