Standard Capture Problem at DVinfo.net
Old December 30th, 2007, 10:23 PM   #1
Using the XH A1
If you have a difficult time capturing HDV footage to your computer using Final Cut, make sure the "PLAYBACK STD" is set to HDV in the signal setup menu.
If the option is ghosted, unplug any external cables and you should be able to access the selection.
24p
60i
capture problems final cut pro
Matthew Nothelfer is offline   Reply With Quote
Old March 16th, 2008, 04:13 PM   #2
hmmm...didn't work for me. only method it will let me capture is with HD-DOWN CONV [ON].
any other suggestions (not that the final version will be in HD...just wondering)?
but I really would like to know how to capture in settings other than DV NTSC...
thanks
PS: footage was recorded 24F
John Stakes is offline   Reply
