deadcat hair do at DVinfo.net
Old June 30th, 2008, 09:44 AM   #1
deadcat hair do
What do people do with their deadcat to get over the problem of hair showing on film, trim with scissors?
Terry Hulf is offline   Reply With Quote
Old June 30th, 2008, 09:59 AM   #2
You need it fluffed up to work properly, so you might need to raise the mic on a shockmount. I use a rode NTG-2 and the SM3 which usually keeps hairs out of shot. I also have a bracket from PagUK which raises it further and gives a couple of other mounting options.
By the way Terry, I hope you don't mind being added by me to the list of Brits on DVinfo:
http://www.dvinfo.net/conf/showthrea...t=26774&page=7
Old June 30th, 2008, 02:41 PM   #3
Images: 18
Hi Terry.....
This works a treat.
Extremely versatile.
http://www.rycote.com/products/softi...nt/softie_cca/
CS
Old June 30th, 2008, 07:15 PM   #4
I fluffed mine all up good then used an electric beard trimmer to shave the long single hairs off. These were the ones that were getting into the corners of the frame. Worked great.
Jim Miller is offline   Reply With Quote
Old July 1st, 2008, 04:25 AM   #5
would the rode sm5 also help solve problem.
Old July 1st, 2008, 05:39 AM   #6
I bought a Rode NTG2, SM5 & Deadcat for my XH-A1 and still suffered from wind noise even though the Deadcat was on top of the NTG2's foam shield on a recent trip to The New Forest in Hampshire.
I did not even realise that it was windy at the time as I was not wearing headphones.
I did think about buying a Rycote Softie but they are very expensive and there is no guarantee that it will work.
I don't think that there is a cheap answer to eliminating wind noise.
Paul W. H
Paul W. Hazeltine is offline   Reply With Quote
Old July 1st, 2008, 06:28 AM   #7
If the mic, or the deadcat in this case, is showing you just have to pull it back, as simple as that. I use the Rode SM5 pushed into the mic holder from the back, no problems with Rode NTG-1 or Sanken CS3 with either deadcat or softie. Some people do not even come to think of attaching the holder "backwards" like this, but push the mic even more forward with the mount and then complain about it showing...
Deadcat or Softie is not enough in serious wind, or even medium. That's what the zeppelins & windjammers are for, but then you can forget on-cam mics.
Petri Kaipiainen is offline   Reply With Quote
Old July 1st, 2008, 09:24 AM   #8
Yes, I was using the SM5 backwards with the mic pushed all the way back but the long hairs still reached the frame. Shaving worked like a champ. Having said all that. The whole set up isn't that great in windy conditions.
Old July 2nd, 2008, 06:39 AM   #9
Paul W. H
The Rode "deadcat" seems to me to be less effective than the Rycote furry cover ("Windjammer"?). The Rycote Softie is better than either, but still only really useful in a light breeze. As mentioned above, a proper "blimp"-style basket is the best, but I have found a useful in-between solution. I have a Rycote Softie on my Rode NTG-1, and then a loose-fitting cover made of furry material that I bought from a craft shop. It works on the same principle as the baskets, creating a region of dead air around the mic, but not quite so thorough. On the other hand, it cost me less than £1 and an evening with a needle and thread, it is small and light enough to sit on the hot-shoe socket, and squashy enough to fit in my back-pack. In most conditions, it's fine. In strong winds, it sound like it's a windy day. However, without it, strongs winds swamp the soundtrack with wind noise to the exclusion of everything else.
Steam Age Pictures - videos in aid of railway preservation societies.
Mark Fry is offline   Reply With Quote
Old July 2nd, 2008, 08:54 AM   #10
Images: 1
This question is just BEGGING for answers that are certainly not appropriate for this forum!
Benjamin Eckstein is offline   Reply With Quote
Old July 2nd, 2008, 08:31 PM   #11
I know this is a lot to ask, but could you possibly post a picture of this set up?
Denise Wall is offline   Reply
