Using Tape Measure For Precise Focus - Page 2 at DVinfo.net
Old April 8th, 2009, 03:07 PM   #16
Originally Posted by Alan Craig View Post
Peter, if you look at your lens there is a red line around it as I think there is on all canon lenses I Think jvc rings are green and I am sure that that is your focal plane and that is where you take measurements from but don't take that for gospel I have never used a tape to focus.
Alan
With the electronic focus I really don't think it will matter if you measure from the front or back of the camera or where your cup of coffee is sitting. There are no hard stops or marked rings to even use for adjustments.
You need a monitor.
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c
Jeff Kellam is offline   Reply With Quote
Old April 8th, 2009, 11:21 PM   #17
Jeff you are probably right and digital cameras have a large DOF, I dont know whether using a 35mm adapter would make a difference with its shallower DOF never used one but as you say the electronic focusing is probably as good as it gets. Like I said in my post I have never used a tape I have allways relied on IAF or manual focusing using the lcd or viewfinder, as for the monitor nice if you have one but can't always carry one out in the field as you could not always use a tape out in the field but do take your point. Now for Colins benefit I am Pretty sure that the line I mentioned in my post is where you should take measurements from which was the original question hope that answers your question if anyone knows different please chime in.
Alan
Alan Craig is offline   Reply With Quote
Old April 9th, 2009, 03:44 PM   #18
I can't understand your problem. I have just interviewed 16 people as part of a project I'm working on mostly framed up from the waist up camera between 4- 7 feet from the subject (I like to get as far back as I can and zoom in slightly - comes from my stills photo days - but not always possible) I put the camera in auto and had no problem whatsoever, perfectly focused.
One the of problems I foresee in a tight manual focus is people leaning and shuffling especially if your aperture is fairly wide open (i.e. no depth of field).
I know many people in this forum disagree with me for using auto settings as much as possible but if it works, it works, why try to 'be the pro' and mess about with tape measures and focus rings if you don't have to just because it is deemed to be the 'professional' way of doing things surely the point is to obtain the satisfactory result
Philip Younger is offline   Reply With Quote
Old April 9th, 2009, 06:45 PM   #19
Hi Alan. Yes, a 35mm adapter makes a big difference. Apart from the shallow DOF, which is of course the main reason for using one, the adapter brings its own focussing plane, which is the ground glass element. If you want to use a tape measure, you need to use the ground glass as the reference. You also need to make sure the adapter and front lens are collimated so that the distance markings on the front lens match up with what the tape measure says.
And you need to focus using the front lens only, the video cam lens focus should stay fixed on the ground glass.
Richard
Richard Hunter is offline   Reply With Quote
Old April 9th, 2009, 08:38 PM   #20
Also when zoomed in if you overexpose the image then focus and then close the iris to the correct exposure it will be hopefully more accurate due to the DOF increasing.
Jonathan Shaw is offline   Reply With Quote
Old May 10th, 2009, 04:53 PM   #21
this is interesting - what camera settings would you suggest?
eg. TV or "A" setting?
Peter Dunphy is offline   Reply
