BNC terminal on the Canon XHA1s at DVinfo.net
Old May 2nd, 2009, 04:51 PM   #1
On the Canon XHA1s, there is a Video 2 terminal. The manual says: “To use the VIDEO 2 terminal, connect the camcorder and TV using a BNC cable (commercially available)”.
The camera BNC terminal is different from other BNC connections I’ve seen. It has a center copper pin. The only BNC connector I can find also has a center pin so they can’t mate. I do understand how Male and Female hook-up (Umm….when it comes to cabling, etc.).
Is there a special kind of BNC connector for this terminal?
Thanks for any and all help.
David B. Sanders is offline   Reply With Quote
Old May 2nd, 2009, 04:58 PM   #2
A standard BNC connector fits onto the camera with no problem. It could be a BNC connector wired onto the cable or an RCA to BNC adapter connector.
Have you tried it?
Old May 2nd, 2009, 05:48 PM   #3
I have some BNC connectors that mate other electronics I have (Radio scanners, etc.) so I assumed that was standard. I spent some time at Fry’s Electronics today and found the same connectors (with center pin). I’ll check Radio Shack. I didn’t think to try the RCA to BNC adapter. I do some more checking and see. But I’ll bet Radio Shack will have the correct BNC connector.
Thanks for responding to my post.
Old May 2nd, 2009, 06:18 PM   #4
Contributor
You probably have one with a female end and you need the male. Like the top picture here:
http://en.wikipedia.org/wiki/BNC_connector
Bill Pryor is offline   Reply
