Optimal aperture setting for XH A1 - Page 2 at DVinfo.net
Old June 29th, 2009, 06:25 PM   #16
Originally Posted by Doug Bennett View Post
Tom to simplify:
You want to shoot at at 2.8
To do so you would need to set shutter at 1/1000
Are you going to shut down the lens or live with the stutter?
I would prefer to add an ND filter (or 2) to cut down the light and try to get the shutter speed to 1/50s or so.
Richard
Richard Hunter is offline   Reply With Quote
Old June 30th, 2009, 12:49 AM   #17
Stop down the lens. Or screw in an ND filter to add to the in-builts. If your camera allows it, use negative gain.
Old July 5th, 2009, 12:08 AM   #18
just to clarify, what is negative gain?
Josh Glowicki is offline   Reply With Quote
Old July 5th, 2009, 02:24 AM   #19
Hi Josh. Gain is used to boost the analogue sensor signal before the A-D conversion stage. Gain values of +3dB, +6dB, +12dB are common on many video cameras. Without any boost the gain is 0dB. If the signal is cut instead of boosted, that is negative gain, for example -3dB. To give you a feel for the numbers, if the signal is cut by half, which is like losing one stop of light, the gain would be -6dB.
Richard
