Custom Function ? at DVinfo.net
Old September 21st, 2009, 12:30 PM   #1
Custom Function ?
Can someone explain what CF 01 (AE Response) does? and do you kepp it on low midle or high. In the Canon documentation online it says that on high it responds like a high end camera. What does this mean?
Howard Churgin is offline   Reply With Quote
Old September 21st, 2009, 04:49 PM   #2
I don't really know, but I'm thinking when set on "high" it is similar to the "shockless off" settings of Gain and WB. There is a reference here http://www.dvinfo.net/forum/canon-xh...teps-pops.html to using the "low" setting to try to smooth out AE bumps. Maybe it's the other way round, which might explain why the OP above found it still didn't work!
The manual doesn't say anything particularly illuminating about how it works
Selects the camcorder's response when you change the automatic exposure setting
"YOU CHANGE?" How can you change it if if it's "automatic"? I'm even more confused now.
I tried changing the settings to see if I could work out what it does, but not so far.
Old September 21st, 2009, 06:01 PM   #3
Thanks for trying. I hope someone can shed some light on this.
Anyone, Anyone?
Old September 23rd, 2009, 07:50 PM   #4
Originally Posted by Colin McDonald View Post
The manual doesn't say anything particularly illuminating about how it works.
"Selects the camcorder's response when you change the automatic exposure setting"
I think that should read "Selects the camcorder's response when you change TO the automatic exposure setting"
Old September 24th, 2009, 12:20 PM   #5
So Bill, do you reckon that the "low/middle/high" refers to the speed of the response?
Colin McDonald is offline   Reply
