#16 |
#17 |
Hi Bill, Jeff did ..or did I read it wrong?
Support your local movie theatre, they need it. |
#18 |
Hi Allan. Oh I see it now, but guess I missed it because he's talking about something else, and think you read him a bit wrong as well. I believe he means since there's no standby/lock switch, there's no way to temporarily turn off the camera and have to revert to using the dial to do so now.
#19 |
Bill, so while recording you can still press the A1s stop function and it'll go into pause, but if you run out of pause time without any operation (30secs), it'll auto shut off then you have to restart using the dial .. is that how you see it?
My guess is Canon might have discovered that leaving an A1 tape sitting in standby lock for a long time was causing trouble, probably overheating, especially doing it repeatedly on a very hot day. Possibly cooked a few tapes. And maybe the A1s standby lever is redundant, with the custom keys you can deactivate the power save function without losing your settings. A1s Power Saving Mechanisms P31, A1 P26. Cheers.
#20 |
Allan, I only have the A1, not the A1s (even though I'd rather have it just for the audio "fixes" :) So I can't comment on the behavior of how the auto shut off (power save, I think it's called, which I think is ridiculous since the large capacity batteries can still run for so many hours it's insane). The first time the power save kicked in and shut down when I first got the A1 years ago, I dug through the menu to disable it. I did however assign the "vcr stop" to a custom key, which basically un-threads tape from the heads during pause mode.
And from what I gather, Canon omitted the standby lock switch because far too many users were accidentally hitting it (who hasn't?) and probably attributed to countless tech calls. |
#21 |
having experienced the panic of discovering the standby switch the hard way - I have to say - I use it all the time now - they should have just moved it instead of removing it!
that sounds very suspicious on the tape drop outs after only 10 hours. Trish |
#22 | |
Hi Trish, just have to get used to being without it. With a customised function you can 'deactivate the power save function' and still keep your settings which is basically what the standby lock does. Dropouts with a new camera has come up before. The consensus with a new vidcamera was to always run a head cleaner tape before any recording is done. This is to clean off any possible factory gunk. Wonder if Jeff did that? Cheers.
#23 |
Jumping Footage on the XH-A1s
Ok I have an example of what I previously called "dropped frames" on the A1s. Looking at the clip closer I notice that it is really a jumping frame. There is no breaking in the timecode and the audio is fine, the footage just jumps! Also I noticed the jump on the camera screen while recording. I thought it was odd at the time.
I wonder if these has something to do with the stabilization in the camera. Let me know what you think. |
#24 |
Looks to me like the handheld camera gets bumped at those spots. I'd mount it on a tripod and record a lot more.
BTW did you run a cleaner tape before the first recording. Cheers.
#25 | |
Also, the Jump is on 1 frame, it would be pretty hard to jar the camera to only effect one frame. Plus I do not remember anything happening that would cause this while I was recording. If you look at the video, the camera is panning at a constant rate, then 2 times it jumps. |
#26 |
Jeff, I see 'em both during that fast pan. If you had the OIS on, then it could be a reaction to that..?
I'd try recording about 15 mins with the cam OIS on, then 15mins OIS off. On a tripod or sitting on a stable table. Point it at something like a fireplace or a goldfish aquarium so you don't nod off :) Cheers. O/T email notifications are working .. I just got 27 old emails
#27 |
Posts: n/a
I completely agree...
I bought an Xh-A1s about 3-4 months ago and I've run into the dropped frames, but it appears as though it doesn't happen on sony tapes, but so far only with fuji (so maybe a tape and head problem), however in my case the timecode does skip, and the color difference is annoying. I've tried everything to match the two and I've had no success. Anyone have any success at matching the presets on these? Like someone stated before the xh-a1s has a higher saturation. Cannon has stated that it was a white balance issue, but I've manually set it and I still get different coloring between the two.
