Free Run Time Code
Anybody knows of a way that I can sync 3 A1 freerun timecode? I will buy you a six pack for sure.
With the Sony Z1 you could use the remote and point at all camera and reset it to sync but I can't do that with A1, the manual said you have to push, but that is no guarantee I can push all camera at the same exact time. )-: |
Perhaps start all thee camcorders rolling from pause on a blank stretch of tape at the same time using a remote control. That should start the time code at zero on each camcorder, and should have the tiem synced within a frame or two. as long as they continue to run withut pause. If you pause a camcorder, use rec search to have them paused at the same frame number and repeast the start process using a remote control.
dpalomaki@dspalomaki.com |
I'm pretty sure this was posted here a while back... the same procedure used for XL2 should work on these cams
http://dvinfo.net/canonxl2/articles/article11.php |
I can't think of any reason why my XL2 Free Run time code article (linked above in Nick's post) wouldn't work for the XH A1. Should be very easy to do.
#5 | |
Nick, send me your address, I will send you a 6 pack of your choice, can't guarantee that it will still be cold though. Man I did not see the menu button on the remote, this is great. khoi@proeditproductions.com |
#6 | |
#7 | |
That feature is going to save me so much time on my next multicam shoot. Took me hours to line up the footage on visual cues, especially when I had 10-12 tapes |
#8 | |
Just a suggestion... MIGUEL |
#9 |
I tried this last night with my new A1s and it failed twice, then we ran out of time. Not sure what happened, but I set the time code on both with the remote. All seemed to be going well. Then once they started running they were a half second off. Hmmmmm.
There was some delay in the signal to the monitor, and one cam had a longer cable than the other, but I can't see how that would lead to 1/2 second. I'll capture the footage today and see how close it is in post. I really hope this works, though. |
