#16 | |
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#17 | |
#18 |
Khoi: Stopping down means closing the aperature, not opening it...
Canon lenses are all pretty good wide open (in low light).. unfortunately the A1 doesn't allow you to hold the stop through the zoom range, so you're limited to wide angle shots.. it stops to 2.6 and 3.4 as you zoom in - But, again, outdoors or in bright situations, don't stop down below f4 if you can help it - and there are plenty of tools available to make that possible. |
#19 | |
1. turn on the color bars on your camera and feed it to your monitor. 2. turn the color all the way down until it is black and white 2. adjust the brightness until you can barely see the difference between the middle and the last bar on the right (pluge bar, they are 3 small black bars in the bottom right corner next to black square) 3.turn the contrast all the way up and then turn in down until you see it stop blooming (using the white square near the bottom left)or until you see a smooth gradient of gray of all the vertical bars 4.put the blue gel fiter over your eyes and bring the color up until the first bar (white) and the blue bar (right below the white bar) has the same shade. 5.adjust the tint until you see the cyan bar (third from left) and the magenta bar (right below the cyan bar) has the same shade. Now that your monitor is calibrated. (-:. If whatever you feed to it does not look right, you know it is the operator or camera fault and not the monitor. BTW if you are using the Dell, turn off the video mode. |
#20 | |
#21 | |
Oh yeah, you are right, I just got up from a late night shoot, and just took a quick glancd at your post and assumed that is what you said because that is what I have heard so many time in the past, you meant closing and not opening, yeah I agreed, closing it past f5.6 making it pretty soft. My bad. |
#22 |
Great info here! Has anyone posted some video on the sample clip section?
#23 |
Keep in mind that video is intended for viewing things in motion, not static images with lots of fine detail. As you zoom out, fewer and fewer pixels are available in the image to resolve the same detail. With motion, the brain-eye system compensates for this loss of detail.
Any delivery system that requires high compression can only make things look worse.
dpalomaki@dspalomaki.com |
#24 |
Agreed on both points regarding the 2407 & the A1. I was extremely disapointed with the 2407 video quality re: colour saturation.
#25 | |
http://rapidshare.com/files/18138889...rpness3_ND.m2v Please note that it was recoreded with sharpness at 3, while the default is 7 for the V1. It looks mush at the beginning, but watch on...
#26 | |
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive Last edited by Piotr Wozniacki; April 23rd, 2007 at 05:23 AM. |
#27 |
Very interesting reading indeed thanks for all the informative posts. I had read that you need to understand this camera to get the best out of it, and I can now confirm that this is totally correct. I'm really please with the footage from my xh-a1 now, and the more I get to know it the better it's getting.
There's actually something quite satisfying about knowing that you need to work the camera to get the best out of it. regards Paul. |
#28 |
Ok so now we know that your sun is as bright as my sun. (-:
#29 | |
#30 |
I don't know if this helps Paul, and I know it sounds kind of obvious, but I've found that the image quality can vary greatly just with different combinations of zoom, focus, shutter, aperture, gain, and custom preset. The particular shot itself in terms of color and lighting is also important -- just walking outside and turning the thing on can result in some pretty dull shots IMHO.
I had that complaint for a little while after I first bought mine -- it seemed I wasn't able to get the clarity and vividness of some of the samples I'd seen -- but as I've gotten to know the camera better, the quality's been improving. You could post some screenshots or a sample video of something you've taken as well, in which case others more qualified than myself might be able to tell if the camera seems to be in good working order. Keep at it! Jared |
