Scratched Lens update - Page 2 at DVinfo.net
Old June 18th, 2007, 01:59 AM   #16
My CP lens is a Hoya and my UV lens is a Cokin.
The Canon lens cover clips nicely on either one of these.
Bill Watson is offline   Reply With Quote
Old June 18th, 2007, 04:59 AM   #17
I have made a photo of the UV lens in front of my A1's lens and enclosed it with this message.
http://www.hdvinfo.nl The Dutch forum and website about HDV & Canon XH-A1
Gert Kracht is offline   Reply With Quote
Old June 18th, 2007, 08:04 AM   #18
Originally Posted by John L. Miller View Post
Being that a dual thread filter has external female threads (72mm), surely a screw end lenscap is available somewhere. I will look into that. I am fairly certain the xh a1 factory lenscap is useless with a filter. J
So this means the factory Canon cap doesn't fit with this filter? I was on ebay about to buy it. If that is the case, have you come across a screw in cap?
K
Kevin Kimmell is offline   Reply With Quote
Old June 18th, 2007, 08:14 AM   #19
I have a UV haze 72m and the canon cap fits just fine. I would assume they all should if they are the same dimension. Naive assumption???
Trish
Trish Kerr is offline   Reply With Quote
Old June 18th, 2007, 08:17 AM   #20
Well is yours double threaded? The one in question has female threads on the outter side to allow for a 2nd filter. I thought from reading a prior note in this thread that someone mentioned that double threaded filters might not accept the factory canon cap.
Old June 18th, 2007, 09:02 AM   #21
Here is the equivalent filter
http://cameras.pricegrabber.com/filt...26601/details/
Didn't realize you needed double threaded solution, sorry.
Trish
Old June 24th, 2007, 07:11 PM   #22
XH A1 Lenscap works with the 72mm hoya filters
It is true! I just found out for myself. The lens cap protector for the XH A1 does easily fit the 72mm hoya filters. So you can leave the filter on forever. I am happy about this. J
John L. Miller is offline   Reply
