It's official: Canon XL2 announced - Page 13 at DVinfo.net
Old August 5th, 2004, 04:11 PM   #181
Andre, if I understand you, that's along the lines I was thinking. Regardless of bit depth of the A/D, Assuming all CCD's and everything else is equal, the brightest white will be the biggest number on each A/D correct? This seems to make perfect sense to me as a programmer, but I'm not up with all the optical stuff.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline   Reply With Quote
Old August 5th, 2004, 05:29 PM   #182
Warden
Andre, I'm not following what your saying. Are you saying 8 bit and 16 bit image files have the same dynamic range?
Jeff Donald
Carpe Diem
Old August 6th, 2004, 03:37 AM   #183
Yes Jeff. The non adaptive CCD dynamic range is the range between the highest signal level (limited by a certain amount of distortion- "white clip" in video)and the lowest signal level (limitted by a certain amount of unwanted vs wanted signals- noise, glare..in cams ). This figure is seldon higher than 45 db in consumer camcorders. Maybe there is a confusion about how well a scene's dynamic range (80db and more) is being "packed"into the limited camers range. This subjective compression
performance is like I wrote (knee processing, gamma, ..) bitdepth dependent.
Andre De Clercq is offline   Reply With Quote
Old August 6th, 2004, 04:45 AM   #184
Warden
Even before processing the 16 bit file would contain more levels of gray (greater dynamic range) that are discernible to the eye than an 8 bit file.
Jeff Donald
Carpe Diem
Old August 6th, 2004, 07:28 AM   #185
Here http://www.fillfactory.com/htm/techn...df/oeepe99.pdf (PDF) is some info on CCD (and CMOS) dynamic range. IMEC is a Belgian micro electronics research center where I used to be a member of the scientific advisory commitee for several years.
Old August 6th, 2004, 10:31 AM   #186
Warden
Thanks Andre, I'll look that over after classes this afternoon. You may be interested in Norman Koren site and his discussion on tonality and dynamic range.
Jeff Donald
Carpe Diem
Old August 6th, 2004, 02:23 PM   #187
Interesting article. Although dynamic range is a well defined ratio, the " hidden dynamic range" approach is a good idea that kinf of explains what I wrote before: using high bitdepths allows manipulating (mainly expand) "hidden" parts in the analog signal.
