Wide angle adapter for the 14X manual lens. at DVinfo.net
Old August 18th, 2004, 03:41 PM   #1
I have posted this in the XL1 forum, but I think that since the 14X manual lens is also compatible with the XL2, it could be relevent here as well.
I think this might be useful for other people in the same situation.
I own the 14X manual lens, and was looking for a wide angle solution cheaper than the 3X lens. After looking to the wide angle adapters from century optics on the B&H web site, I found that these adapters come in two types: one with a bayonet mount, to mount in place of the sunshade hood on the 16X auto or the 3X, and another one that can be mounted on the 16X manual lens. No word about the 14X.
So before spending my money, I emailed century optics about that and here is the reply I received from Robert Orlando:
quote:
Hi Jean-Philippe,
For the 14x on the XL you will need the following:
VS-07CV-75 .7x Wide Converter, 75mm (full zoom capability) $795.
VS-06WA-75 .6x Wide Adapter, 75mm (fixed wide angle) $395.
These adapters clamp-on to the outside of your lens. They will not
work with the 16x Servo nor the 16x manual.
Best regards,
Robert
Schneider Optics - Century Division
These two items are available at B&H.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old August 22nd, 2004, 02:36 PM   #2
Many thanks, Jean-Phillipe. The .7x zoom-through is a better item for some folks. However, not only is it more expensive, but it's heavier as well. The .6x is not zoom-through but is much lighter as well as being much less expensive.
Chris Hurd is offline   Reply
