Where would I find my serial number? at DVinfo.net
Old November 1st, 2004, 12:36 PM   #1
I've recently received a new XL2 PAL unit and am going through the motions of filling out my Mack Warranty and customary paperwork. I can not locate the serial number for this unit on my invoice and the manual states that it can be found "at the battery attachment unit".
What is the "battery attachment unit"?
There is a big barcode with a lot of different numbers on the hand-grip/zoom control just to the side of the lens mount.
There are no other numbers that I can discern on the unit anywhere else.
Any ideas?
Regards,
Chris
http://www.lizardlounge.com
Chris Mills is offline   Reply With Quote
Old November 1st, 2004, 12:39 PM   #2
Remove the battery and look in the well.
RB
"The future ain't what it used to be." Yogi Berra.
www.rbravo.com
Rick Bravo is offline   Reply With Quote
Old November 1st, 2004, 12:40 PM   #3
Chris,
Look inside the square "hole" where you attach the battery on the right side of the camera. You should see a set of numbers under a barcode... if this is the one you mention, then yes, that's your serial number.
Richard
Richard Alvarez is offline   Reply With Quote
Old November 1st, 2004, 12:43 PM   #4
And if there are no numbers at all in the battery attachment unit? (insert sinking feeling)
Edit:
Here's a link to a photo of the battery attachment unit on the camera:
http://ambientspace.com/blog/images/xl2PAL.jpg
And this is a photo of some official looking sticker on the box. The top one is the same as the one which is located on the camera grip. Which of these numbers is my serial number?
http://ambientspace.com/blog/images/xl2PAL_2.jpg
Regards,
Chris
Old November 1st, 2004, 01:24 PM   #5
Chris, the sticker that's located on your camera grip -- can you post a shot of this as well?
Old November 1st, 2004, 01:47 PM   #6
Yeah,
That doesn't look like my battery well at all... something is weird here.
Old November 1st, 2004, 01:48 PM   #7
Here's a photo of the sticker on the grip of my camera:
http://ambientspace.com/blog/images/xl2PAL_3.jpg
The sticker on the grip and the upper sticker on the box photo are the same. I am sure that one of the sequence of numbers on these is my serial number. They are in the following format:
(xx)xxxxYxxx (xx) YY (xx) xxxxxxxxxxxx
xxxxYxxx [YY] xxxx
Where "x"= number and "Y"=upercase letter.
Regards,
Chris
Old November 1st, 2004, 04:59 PM   #8
Dont know what to tell you Chris, my serial number is a twelve digit number. But I have an NTSC model, not PAL. So perhaps there is a distinction in the numbering system. Anyone with a PAL model care to comment?
Old November 1st, 2004, 05:10 PM   #9
Who did you buy the camera from? Was it a dealer in New Zealand or elsewhere?
Old November 1st, 2004, 05:36 PM   #10
Singapore.
I suspect that I am fine in that the numbers on the box match the numbers on the camera. I realise that I am not covered by a NZ specific warranty and that if I run into any trouble I will be stuck dealing with the Mack Warranty for any warranty related servicing.
I am hopeful that this will not be a problem and that it was worth the risk of saving on local prices.
Regards,
Chris
Old November 2nd, 2004, 12:48 AM   #11
Was this grey market?
David Lach is offline   Reply With Quote
Old November 2nd, 2004, 01:23 AM   #12
Grey market means no warranty coverage at all. So technically I don't think this is a case of grey market, though I may be splitting hairs.
While the manufacturer's warranty is not covered in NZ- the international, third-party Mack Warranty is. I would need to do a bit of a dance and potentially be out of pocket until MW reimburses me (should a warranty repair be requried). Other repairs would obviously be covered by standard rates.
Regards,
Chris
Old November 2nd, 2004, 04:47 AM   #13
RED Code Chef
I think PAL camera's do this differently. I didn't have a manufacture
date on my PAL XL1S as well (NTSC models did). I don't have an
XL2, so can't help in that regard.
Rob Lohman, visuar@iname.com
Old November 2nd, 2004, 06:02 PM   #14
My PAL XL2 definatley has the serial in the Battery compartment as stated........
Mike Hardcastle is offline   Reply
