What's the best way to..... at DVinfo.net
Old March 18th, 2006, 07:14 AM   #1
I need to run from the sound board into my XL2. I was bringing 4 sub-channels from the sound board into a Presonus Firepod, adjusting volume from there and then running out from the Presonus Pre-amp with a line into channel 3 of the XL2. Is there a better way of doing this?
Chris Fritsche is offline   Reply With Quote
Old March 18th, 2006, 10:58 AM   #2
No you're doing it right, have the soundman give you the sub-mix outs to your mixer then take that to the cam... good luck. One thing to consider, taking that sub-mix you're going to be getting a mix that is post effect, so vocals will have a ton of verb or echo on them, they'll sound great for the house but may be saturated for your video. You might want to work on this with the soundman to see if there is a way that you can pull audio from the pre-fader send to your mixer and take a non-fx mix.
Miguel
Miguel Lombana
http://www.miguellombana.com & http://www.phoenixhamradio.com
Miguel Lombana is offline   Reply With Quote
Old March 18th, 2006, 02:08 PM   #3
Thanks Miguel, I will talk with him before service tomorrow.
