XL2 and EF Lens Adapter / EF Lenses / EOS Lens - Page 5 at DVinfo.net
Old September 29th, 2004, 06:47 PM   #61
see my new thread in the XL1S watchdog section with comparisons of lenses with the EF adapter.
http://www.dvinfo.net/conf/showthrea...threadid=32734
Tom Duncan is offline   Reply With Quote
Old September 30th, 2004, 09:49 AM   #62
I received my XL adapter a day or two ago and decided to try it with a tamron 200-500mm lens I have.
What was impressive was the amount of the zoom I could use. If you want to improve your chances of getting some great wildlife stuff, eagles, birds, etc, I would recommend this to you. The tripod should be solid and I don't think you could even consider this a handheld option, but I was impressed with the sharpness and quality.
BTW, I'm using an XL2
DBK
Darren Kelly is offline   Reply With Quote
Old October 4th, 2004, 12:20 AM   #63
XL2 and EF lenses
There is now a footage at www.luontovideo.net/XL2-lens-test.html demonstrating the image one gets with the XL2 PAL in 25p mode using the XL-EF adapter and various EF-lenses. The lenses I used were:
XL 3x 3.4-10.2mm and
XL 20x 5.4-108mm lenses
EF 17-35mm F/2.8L USM,
EF 70-200mm F/2.8L USM,
EF 100-400mm F/4.5-5.6L IS USM,
EF 400mm F/2.8L USM.
The file is rather big, 207Mb, and an avi file employing the Microsoft codec. (The clips were imported to Premiere through a standard firewire port.) Some fog appeared, when I attached the EF 400mm lens, and it shows.
Some comments:
The EF 100-400mm lens was very difficult to focus in the 400mm end. I do not find personally that lens useful. Neither the EF 70-200mm was easy to focus.
Some first impressions of the XL2 compared to the XL1:
Improvements: Audio, nex 20x lens, sharpness, colors, knee & black adjustments, custom functions, optical image stabilator
Improvements but could be further developed: display (can't see any flickering), audio inputs (balanced line input missing, but can live with that)
Not happy about: The iris/set knob (would have preferred the dial of XL1 but can live with the new knob) and with the mechanical design of the plastic covers of the inputs; My concern is that the small rubber rod between the cover and the camera body will break in parts at some point next winter.
Lauri Kettunen is offline   Reply With Quote
Old October 4th, 2004, 12:45 PM   #64
yes, it is a nice color-show. Can't play the video, only some color blocks. Do we need a codec?
Lasse Bodoni is offline   Reply With Quote
Old October 4th, 2004, 01:04 PM   #65
Yea, you have to recompress it. someone can get a seizure from that file.
Mark Grgurev is offline   Reply With Quote
Old October 4th, 2004, 01:07 PM   #66
how do we recompress the file?
Rabi Syid is offline   Reply With Quote
Old October 4th, 2004, 01:20 PM   #67
Hmm, somebody seems always to have some problems. Guess one needs Premiere or some other software to view the clip. I'll create another version of the clip as soon as have a chance for that. Sorry for the inconvinience, "please do not shoot the pianist."
Old October 4th, 2004, 01:50 PM   #68
RED Code Chef
This has nothing to do with compression or re-compression. It is
a DV file and something went wrong. It is indeed faulty. I suspect
something went wrong when you uploaded it (perhaps your FTP
program was set to text while uploading instead of binary mode).
Rob Lohman, visuar@iname.com
Old October 4th, 2004, 02:13 PM   #69
it isn't a software issue but a codec or encoding
Old October 4th, 2004, 02:27 PM   #70
Rob, thanks, you guessed the source of problem. It was in ftp and the default ascii mode it assumed.
I just deleted the old avi file and a new one will be available in couple hours.
Please wait till 11:30 pm London time before trying to download the new file.
(I'm filming at the altitude of the artic circle and it takes some time to ftp the file again to the server for I have only a slow connection available.)
Old October 4th, 2004, 03:17 PM   #71
Really Thanks Lauri !!
You are very very Kind
Best reagards
Gabriele
Gabriele Turchi is offline   Reply With Quote
Old October 5th, 2004, 01:45 AM   #72
RED Code Chef
The file is okay now indeed. Glad I could help in solving the
problem. Thank you Lauri for putting the footage up!
Old October 5th, 2004, 12:04 PM   #73
I made another sample demonstrating XL2 together with EF 400mm/f2.8 L USM lens. The sample requires canopus codec and is available at
There are two clips in the sample. The other object was taken 100 meters away and the other 6 meters away from the camcorder. Be aware, that since the magnification with a 400mm lense is huge, when the object is far away, humidity and the motion of air easily blur the image. This sample was taken in rather good conditions in this respect.
Old November 2nd, 2004, 12:50 AM   #74
EF adapter w/ Sigma 12-24mm lens?
Has anyone used the Sigma 12-24mm lens with the EF adapter? I'm concerned about being able to change the aperture electronically because there's no aperture ring on the lens. Also, is it true that the EF adapter doesn't autofocus with 35mm lenses?
Tony
"Good taste is the enemy of creativity" - Picasso
Blog: http://www.tonyhall.name
Tony Hall is offline   Reply With Quote
Old November 2nd, 2004, 03:02 AM   #75
Tony
I haven't used this specific lens, but I have used other Sigmas with the EF adapter. You change the aperture using the camera's iris wheel (or whatever you call it on the XL2) in exactly the same way as you do with the stock XL lenses.
Yes, it is true that you lose any autofocus function on a 35mm lens when using the EF adapter.
Regards
Duncan
Duncan Wilson is offline   Reply
