Timecode erases!!! at DVinfo.net
Old October 4th, 2006, 06:28 PM   #1
Timecode erases!!!
My roommate and I have the same messed up problem I have a XL2 and he has a Xi, when I record something on my it generates timecode and recordes, but when I try to play it back there's no timecode on picture no a nothing. His camera does the same thing, its never done this before we both use the same computer and use vegas 6. Help please!!!
Travis McMunn is offline   Reply With Quote
Old October 4th, 2006, 11:48 PM   #2
Hi Travis. Not sure from your post how you are seeing (or rather, not seeing) the missing timecode.
If you connect the camera (in VCR mode) to your PC via firewire and run the Vegas capture application, you should see the timecode displayed, not on the picture, but at the bottom right of the pane that contains the preview window. If you play, fast-forward or rewind, you should see the timecode change accordingly. If this is working OK for you then you know the timecode is being captured correctly on tape.
Richard
Richard Hunter is offline   Reply With Quote
Old October 5th, 2006, 12:45 PM   #3
I found that it is not erasing anything I put one of my tapes into a mini dv deck and it played back fine, but when I put the same tape into the XL2 there was no timecode or picture. My camera when recording generates timecode and it seems to be working but when I rewinded the tape there was was nothing, but in the sony tape deck it played fine. So in other words my camera will not play back or record a tape.
Old October 5th, 2006, 12:55 PM   #4
I think you have to set the menu in the camera, in order to see it.
Michael Cassidy is offline   Reply
