Nikon lenses on the XLh1 at DVinfo.net
Old June 16th, 2008, 01:35 PM   #1
Hi guys
Quick question. If you use Nikon stills lenses through a glassless type adapter on the XLh1 would you still have control of shutter speed?
I think with the fujinon XL fit x14 lens on the XL the lack of communication meant shutter speeds were unavailable !!?? http://www.dvinfo.net/canonxl2/articles/article04.php
Cheers
Mat
Old June 16th, 2008, 01:49 PM   #2
Оf course you have control, you'd shoot everything in Manual mode, setting up your diafragm on the lens and shutter on camera.
Oleg Kalyan is offline   Reply With Quote
Old June 16th, 2008, 02:29 PM   #3
OK....so I'll re-phrase the question. On the link above what are they refering to when they mention a slow-shutter function not being available due to lack of communication with the body...which is the same situation you'd be in using the Nikon lens?
Old June 16th, 2008, 03:07 PM   #4
In a manual mode you have access to all shutter speeds that camera body allows.
You have to watch for correct exposure via setting up a correct F stop, using external ND filters, etc. What they mean is that you loose automatic exposure adjustment.
Old June 16th, 2008, 03:54 PM   #5
You do have auto-exposure adjustment (although not full "program"...but who would want that anyway...) using the Canon XL body with a Nikkor lens.
As mentioned earlier, you simply set the aperture of your choice by revolving the click-stop aperture ring, and then set the video camera body to "AV" and let the Canon XL body automatically adjust to the constantly changing light levels. Or, if you prefer, set both aperture and shutter speeds manually.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old June 16th, 2008, 04:04 PM   #6
Ahhh....got ya! That makes a lot more sense. I guess seeing 'shutter speeds' kind of threw me in a little!
Tony....Do you use any Nikons on the XL range!? I have to say I like the idea of removing the XL adapter and its glass, 1 item less to cause issues !
Old June 16th, 2008, 04:13 PM   #7
Yes, I use all my Nikkors from 20mm to 600mm ED-IF.
To attach the Nikkors to the Canon body, I use the Nikkor-Canon XL adapter made by Les Bosher.
Just make sure that you use Nikkor lenses that have a manual aperture ring - do not use any of the "G" range of Nikkors or you'll not have iris control.
www.WILDCARP.com
www.NIKON.me.uk
Old June 16th, 2008, 04:34 PM   #8
Ok, thanks for that.
Have you got the 80-200 F2.8 ED? I've been trying it today on the JVC and while its very sharp and has nice colours the manual focus ring is poor. Very tricky to hit focus without lots of tweaking!
Old June 17th, 2008, 04:03 AM   #9
That's why I prefer MF lenses rather than AF lenses.
The older Manual focus well-built professional-grade lenses are just as sharp as the later AF lenses, but most of the MF lenses have very large and wide manual focus rings with a silky-smooth action.
Also, the manual super-telphoto lenses such the Nikkor 200mm f/2, 300mm f/2, 300mm f/2.8, 400mm f/2.8, 400mm f/4.5, 500mm f/4, 600mm f/4, 600mm f/5.6, 800mm f/5.6 and 800mm f/8 all have a focus-range adjuster - where you can preset the lens at any focal distance, focus at a different distance and then quickly bring the focus back to the exact same original place.
www.WILDCARP.com
www.NIKON.me.uk
Old June 17th, 2008, 05:56 AM   #10
Tony,
May I ask what approximate focal length magnification factor you are experiencing when using still lens on your XL-H1?
Thanks much.
Old June 17th, 2008, 07:48 AM   #11
With a 1/3rd sensor camera its about 7x.
Mat Thompson is offline   Reply
