Frame Rate at DVinfo.net
Old November 7th, 2007, 10:33 AM   #1
Frame Rate
I should have asked this a long time ago I think, but how do I change the frame rate on my Canon XL1S???
I think I've got the term right.
I'm trying to understand the difference between 25p and 60i at the moment, my head hurts.
Ta
Dave
Dave Robinson is offline   Reply With Quote
Old November 7th, 2007, 01:43 PM   #2
Can you have both of those? One is PAL, and one NTSC, right?
Alex Sprinkle is offline   Reply With Quote
Old November 7th, 2007, 02:30 PM   #3
Dave,
You either have a PAL camera at 50i or 25p, or and NTSC camera at 60i or 30p. Its been a while since I had mine, so check you manual for how to switch, I don't remember if it was an external switch or not.
You probably have a PAL camera based on where you live.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old November 7th, 2007, 02:41 PM   #4
From what I recall, you can go to 50i to a form of 25p using the menu. Look for movie mode. Normal is 50i and frame is 25p.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old November 8th, 2007, 03:40 AM   #5
Ahh sorry I've got myself confused with the difference, I was just spouting numbers based on what I'd heard.
Right my camera is a PAL XL1S. I read the manual and it mentions nothing about "frame rate" it does however mention movie mode being similar to cinema settings. So from what Jean-Phillippe said normal mode on the camera is 50i and Movie mode is 25p? Is this correct?
Right now this is gonna be a really stupid question. Which is best? Or can someone give me a break down of the benefits and drawbacks of the two different modes. I mean in theory 25p should be better as it's closer to 35mm film cameras, no?
