xl1s image/color problems at DVinfo.net
Old November 11th, 2001, 10:15 PM   #1
I'm having trouble with striped or patterned objects "crawling" or moving in a zebra-like manner when I shoot. Also, reds and other deep colors tend to "crawl" as well. What am I doing incorrectly?
Lorinda
Old November 12th, 2001, 11:38 AM   #2
Its not the zebra indicating exposure over 95 IRE is it? That can be set via the menu and appers on the EVF and default analog output while in camera mode.
Over saturated colors and reds will tend smear anad crawl when copies to analog color under systems (e.g., VHS) and when coupled to TV sets using analog connections. Using a proc amp to reduce color saturation on the analog output can halp.
Old November 12th, 2001, 12:27 PM   #3
Thanks so much for taking the time to answer. I'll check it out!!
Lorinda
Lorinda Norton is offline   Reply
