Interval menu in pink? at DVinfo.net
Old October 3rd, 2006, 07:44 AM   #1
Hi guys....Well this is my first post on this forum after lurking for a month or so.
So a BIG HELLO to one and all....
Ok then, I have a small issue which is probably easy to solve but I'm struggling with....My XL1S menu is pink(unavailable) when I try to set up the interval/timelapse function. Does the camera need to be in a certain mode/setting for this to be set up? Can anyone shed a little light on this??
Old October 16th, 2006, 03:47 PM   #2
Hey guys.....I'm stumped on this one......if anyone could help it would be great :)
Old October 16th, 2006, 04:00 PM   #3
Make sure that there's a tape cassette in the camera ready for recording, and that you're not in the Green Box (easy recording) program mode. Use either the A, Tv, Av or M program modes.
Old October 17th, 2006, 07:39 AM   #4
My cam stays on manual pretty much......but yes you got me. It only makes sense really you need a tape in the set up an interval timer...:) Problem solved..........doh!
Cheers fella
Old October 17th, 2006, 07:54 AM   #5
The sad thing is that this isn't mentioned in the XL1S owner's manual.
Chris Hurd is offline   Reply
