XL1s Sports situation at DVinfo.net
Old November 12th, 2006, 09:16 AM   #1
I'm going to be using my XL1s for some gymnastics next month. I'd like to use the frame mode for a clean slo-mo. My question is this, will the frame mode deliver a clean slo-mo or will the normal interlaced footage provide the best results (de-interlacing the normal material in post of course). Thanks.
Ben
Ben Lynn is offline   Reply With Quote
Old November 12th, 2006, 05:28 PM   #2
Normal will probably slo-mo better for smooth motion because the motion is sampled every 1/60 (NTSC) while frame mode is every 1/30 and thus has more motion between each field image.
But do test with moving subjects to see which works best for you.
dpalomaki@dspalomaki.com
Old November 12th, 2006, 11:22 PM   #3
I used to shoot (birds) in frame mode using shutter speed of 1/50s' (PAL) to get nice footage.
But now I shoot in NORMAL mode for the reason of getting slo-mo.
If you like smooth footage WITHOUT slo-mo then use shutter speed of 1/60s', (use ND filters if needed).
When slo-mo is REQUIRED, you need to shoot interlaced, and raise the speed
to 1/500s' or 1/250s' (better experiment to see what shutter speed freezes the motion).
The smooth slo-mo is acquired by transforming each half frame into a full frame (same as shooting in frame rate of 60p instead of 60i) , in post.
I second Don that you need to experiment first with the lightning condition and the speed required to freeze the motion.
Sassi
Sassi Haham is offline   Reply With Quote
Old November 13th, 2006, 06:40 AM   #4
Thanks for the info. On this shoot I won't have time to experiment with anything so I turned here to find out what works and doesn't. It's not a major issue where someone will point out if the slo mo isn't clean, but I try and make things look the best I can when possible.
Ben
Old November 14th, 2006, 07:44 PM   #5
You can experiment by simulating the action, even in another venue, as long as the action speed is about the same; e.g., have someone run past you, toward you, away from you down the street, in a gym, etc.
Don Palomaki is offline   Reply
