Prospect footage in 32bit AE project at DVinfo.net
CineForm Software Showcase
Old September 18th, 2007, 05:15 PM   #1
When I drag my Prospect footage into an AE8 project it looks fine in 8 and 16 bit but when I switch to 32bit the gamma goes way off. I need to apply a gamma of 1.8 or so in order to get it to look like it would in PP3.
I tried this last week with some Aspect HD footage before I upgraded and it worked fine.
Any hints?
-- Bruce
Bruce Findleton
Land's End Productions
Pleasanton, CA
http://www.landsendproductions.com
Bruce Findleton is offline   Reply With Quote
Old September 18th, 2007, 05:23 PM   #2
CTO, CineForm Inc.
The behavior is correct. 32-bit modes have a linear presentation, our plugins automatically output linear for 32-bit modes. 2.2 is the gamma correction required if you don't use the benefit of linear (a subject for a whole other thread.)
Old September 18th, 2007, 06:12 PM   #3
You got that right.
Is there any setting that can be adjusted to keep everything in gamma corrected space without having to apply a gc to every clip?
Bruce Findleton
Pleasanton, CA
Old September 18th, 2007, 06:22 PM   #4
CTO, CineForm Inc.
Use an adjustment layer.
Old September 18th, 2007, 06:26 PM   #5
Sorry, I put that poorly, that's what I meant and was looking for a way to avoid it. Thanks anyway.
Bruce Findleton
Pleasanton, CA
Old September 18th, 2007, 08:40 PM   #6
On a side note, when I Alt-click on a Prospect HD file in the project window it shows up as AVIV uncompressed. How does AE know this is a Cineform file? Just curious.
Bruce Findleton
Pleasanton, CA
Old September 18th, 2007, 10:54 PM   #7
CTO, CineForm Inc.
I asked Adobe that, it seems they new API still has some glitches.
Old September 20th, 2007, 02:50 PM   #8
The same happens here, but only with latest Prospect 138build. It appears that AECS3 is not recognizing the Cineform Codec. When I use RAW files, the project windows is loading the file as Uncompressed AVIV too.
When I uninstal the latest version and Install build 135, After Effects is loading the clip right.
It seems that there is something missing in the new CFHD importer for AE. It can coexist with the AVI and DirectShow importers now, but you cant use the codec options, and aftereffects is not recognizing the file type.
Prospect footage in 32bit AE project-build135l.jpg   Prospect footage in 32bit AE project-build138l.jpg
Sergio Sanchez is offline   Reply With Quote
Old September 20th, 2007, 03:36 PM   #9
I just upgraded so the 138 build is all I've ever used. And look at the difference in picture quality: After Effects screen grab compared to Premiere.
Prospect footage in 32bit AE project-ae.jpg   Prospect footage in 32bit AE project-pr.jpg
Bruce Findleton
Pleasanton, CA
Old September 21st, 2007, 10:13 AM   #10
Curious. The above just appears to be a display issue. If I render a frame to a .tiff it looks fine. Any ideas why the display should look so bad?
Bruce Findleton
Pleasanton, CA
Old September 21st, 2007, 10:52 AM   #11
CTO, CineForm Inc.
In Premiere you are seeing the CineForm scaler, in AE your are seeing the Adobe preview scaler (sucks doesn't it?) This is not a bug. In AE, I mostly use 50% or 100% view, not Fit, which causes the scaling unpleasantness.
Old September 21st, 2007, 10:53 AM   #12
I had a similar problem in AE 7.0 but it only happened when Open GL preview was turned on. If I used the advanced 3d option. The preview were ok.
Old September 21st, 2007, 11:10 AM   #13
Both views were at 100%. It's still the same regardless of preview mode.
Bruce Findleton
Pleasanton, CA
Old September 21st, 2007, 11:13 AM   #14
CTO, CineForm Inc.
Then you don't have something installed correctly. Sorry I don't know what that is.
Old September 21st, 2007, 12:49 PM   #15
Dropped my 1440x1080 footage into a 1920x1080 comp and all is well. The 1440x1080 comp was causing the problem for some reason.
Bruce Findleton
Pleasanton, CA
