Latest P2K Build does not recognize old RAW footage at DVinfo.net
CineForm Software Showcase
Old September 25th, 2007, 09:56 PM   #1
The latest P2K builds (3.0+) does not seem to recognize old RAW footage from very earlier on (I don't know exact version of the RAW) but it was almost a year back. The Premiere Pro seems to show the files but there is discolor during scrubbing. AE does not show these files at all. The 2.0+ versions work fine.
This causes problems in the licensing too as the license for the 3.0 version seems unacceptable if you install older version to edit older RAW footage.
Last edited by Bhaskar Dhungana; September 25th, 2007 at 10:00 PM. Reason: Incomplete info
Bhaskar Dhungana is offline   Reply With Quote
Old September 25th, 2007, 10:07 PM   #2
CTO, CineForm Inc.
Your old file may simply need the headers updated -- there is a tools for that. Contact SI support first, as they are more aware of which files are impacted, and I have sent them the tool. If that is not the error, then CineForm support will need a sample file to address the issue. All sounds very fixable, so you can be using P2K v3 all the time.
Old September 25th, 2007, 10:55 PM   #3
Hey Bhaskar,
The header update program is on the way.
Jason
Jason Rodriguez is offline   Reply With Quote
Old September 26th, 2007, 11:46 AM   #4
If you disable de Metadata in AE your files will playback
Sergio Sanchez is offline   Reply
