Prospect HD: 1440x1080i missing? at DVinfo.net
CineForm Software Showcase
Old January 5th, 2008, 11:38 AM   #1
Which project settings do you use in Prospect when capturing HDV 1080 50i?
thx
Eric
Erich Reisenberger is offline   Reply With Quote
Old January 5th, 2008, 11:53 AM   #2
CTO, CineForm Inc.
We could add that preset, and so can you. It is not there for historical reasons, Prospect HD used to be bunded with AJA Xena cards which don't have a 1440x1080 mode.
Old January 5th, 2008, 11:56 AM   #3
Because my Aspect Trial has expired so you suggested to continue for another 15 days with ProspectHD.
How to fit that in? And does it then capture from APP2.0 with my Canon XH-A1?
thx
eric
Old January 5th, 2008, 12:05 PM   #4
CTO, CineForm Inc.
Yes. Preset are just, presets, you are create your own at differents resolutions and choose the capture device for HDV. To make it simple Aspect HD presets run in PHD (attached.)
unzip and install in C:\Program Files\Adobe\Adobe Premiere Pro CS3\Settings\en_US\CineForm
Old January 5th, 2008, 12:26 PM   #5
thx a lot. Yes that's what I tried now - I get it in the project settings - startet a new 1440x1080i Project, take CINEFORM HDV CAPTURE and changed device controll to phd crash device controll, but it says the camera is offline. Do I unstill Prospect, the device control works with DV/HDV device controll.
Eric
Old January 5th, 2008, 12:29 PM   #6
CTO, CineForm Inc.
Use the presents I sent you. The Crash Record Device Control is for HDSDI users, you want the CineForm HDV Device Controller.
Old January 5th, 2008, 12:41 PM   #7
Sorry just does not work. I did as you said - and it says "There is any severe mistake .... Premiere has to stop....(translated from German into English). I also tried to put the settings instead of en_us into de_DE. Aspect automatically installs the plugin and settings into the de_DE Folders.
thx Eric
Old January 5th, 2008, 12:47 PM   #8
CTO, CineForm Inc.
What doesn't work? The presets or the correct device controller. Install wherever your preset go. All other question should go to support now.
Old January 5th, 2008, 12:49 PM   #9
It doesn't recognize the canon xh-a1 and scene detection doesn't work. So from within premiere i can't control the camera.
thx
eric
Old January 5th, 2008, 01:29 PM   #10
CTO, CineForm Inc.
Now a stock support issue. I don't work in that area. Sorry.
