10bit and 8bit selection in Prospect 2K at DVinfo.net
CineForm Software Showcase
Old April 27th, 2008, 08:24 AM   #1
hi there,
I'm using prospect 2K and working with some SD footage in SD timeline using Adobe Premiere Pro CS3... while adjusting the settings for the project I didn't see any switches to indicate what bit depth the project will be? I only found the " maximum bit depth" option in adobe premiere,, and in the Export settings window of the cineform encoder I found use 4:4:4 encoding..
am I like this working with 10bit color depth in my timeline and the exported CFAVIs? or there where a different settings I should have done to ensure that I'm working with a certain bit depth? if yes, then how can I switch it to 8bit?
thanks in advance
Mohammed El Sharqawy is offline   Reply With Quote
Old April 27th, 2008, 09:05 AM   #2
CTO, CineForm Inc.
Only the playback settings control -- "use 32-bit ..." sets the quality for exports in CineForm presets.
Old April 27th, 2008, 10:13 AM   #3
the presets doesn't indicate any bit depth options...
Old April 27th, 2008, 10:14 AM   #4
CTO, CineForm Inc.
In the playback Settings there is a control for bit-depth.
