Portable workflow question at DVinfo.net
CineForm Software Showcase
Old June 30th, 2008, 09:35 PM   #1
Hey guys, do you think this is a robust portable workflow? No dropped frames, etc...
HV30 -> HDMI -> (Magma enclosure + Blackmagic Intensity) + Macbook Pro + Firewire 800 + G-Tech G-Raid Mini???
http://www.g-technology.com/products/G-RAID-mini.cfm
If I use realtime capture using Cineform.
John
John Palaganas is offline   Reply With Quote
Old June 30th, 2008, 10:56 PM   #2
John, I don't think you need Raid if you capture with Cineform.
Regular 7200 rpm SATA HDD would do fine.
Also, I have 2 HD capture setups based on Intensity, one of them is mobile - it fits in the pelican case *including the 20" HDMI monitor* and a mini desktop PC.
Works great. I even powered it by the car battery on location, worked flawlessly. (You can see Newegg ad on our website; external scene was shot with it.)
Will sell it soon, since I have another one now.
Alex Raskin is offline   Reply With Quote
Old June 30th, 2008, 11:25 PM   #3
Hehe you're selling your portable system? :)
I have 200GB 7200 rpm on my Macbook Pro. Cineform is about 80mbit/s right? So how much Cineform footage can I store per 100GB via realtime HDMI capture?
Cheers,
John
Old June 30th, 2008, 11:48 PM   #4
Roughly 30Gb/hour with the highest quality ("Large") Aspect HD setting, after 2:3 pulldown removal.
Probably a bit larger file size for Neo/Prospect HD.
This is on PC side with AVIs.
