An alternative way of HD going SD DVD. at DVinfo.net
CineForm Software Showcase
Old February 25th, 2009, 10:30 AM   #1
Guys. Anyone read about this? I think it's a pretty good alternative for converting HD to SD DVD.
David?? Any thought, perhaps?
http://invertedhorn.axspace.com/hdv2dvd_basic.html
Desmond Sukotjo is offline   Reply With Quote
Old February 25th, 2009, 11:33 AM   #2
If you're using Cineform, the whole Debug mode isn't necessary.
Personally, i'd take advantage of saving out the Cineform file, and using AVISynth to resize, and frameserve it straight to the encoder.
VirtualDub is a great tool, but any processing requires RGB conversion....An unnessary step...
I've used AVISynth with success in the past, and assume that the encoders shouldn't have a problem reading the .AVS script to accept the Cineform codec...
Old February 25th, 2009, 06:13 PM   #3
VirtualDub in here is only for previewing purpose. It is not being used in the convertion workflow.
The point of using Debugmode is strictly to save your hard drive space, and eliminate the wait for first step rendering (which is timeline to CineForm AVI). If your timeline is CineForm, then your output (signpost) should be CineForm when you use Debugmode, is it not?
Old February 25th, 2009, 10:02 PM   #4
Yes Desmond...
You are totally correct..
But the workflow suggested on the site, is most likely for people who've never heard of Cineform, or for the days when Hard Drive space was really expensive..
Firstly, the Cineform workflow is primarily for people who do serious CC, and need immediate playback and undisturbed quality on the timeline.
Secondly, i believe that the handoff between PPro and Debugmode is probably somewhat slower than an AVISynth script sraight to the encoder anyways...
By saving out to Cineform, and serving back to your encoder, yes, you're creating an extra step, and some extra harddrive space, but i'm pretty sure the finished footage for optical media shouldn't be more than two hours anyways...What's that in Cineform? About 120gigs?
Not a big deal...
I'm sure an encoder like CCE can eat up the AVISynth script pretty quickly...
Old February 25th, 2009, 10:09 PM   #5
Quote: I assume that the encoders shouldn't have a problem reading the .AVS script to accept the Cineform codec
Without getting into the pros and cons of the two methods above, I can confirm that Procoder, TMPGEnc Xpress and CCE can happily from encode Cineform files opened by way of an avisynth script.
Old February 25th, 2009, 10:25 PM   #6
Yes, i'm looking forward to some test results in the future..I'm really curious as to CCE encode speeds...
Old February 26th, 2009, 12:02 AM   #7
The workflow is to output the Timeline -> Debugmode Signpost -> AviSynth -> MPEG2 Encoder.
Or
Timeline -> Output as CineForm AVI -> AviSynth -> MPEG2 Encoder.
If the quality results the same, we don't need to output to CineForm AVI first.
Positive, TMPGEnc.4 takes AviSynth script.
But I haven't done quality comparison to HDLink downconvert.
Old February 26th, 2009, 08:39 AM   #8
The group over at the Adobe Premiere forum have been discussing this in huge topics for at least 9 months. I think their original idea was to do the HD-SD conversion with free tools.
I didn't think it was relevant to me, since I just imported with HDlink, and exported and down sized per Cineform's instructions (File-Export -Movie), and got what I thought were good results.
Are you all saying, that these tools should be incorporated into the Cineform workflow?
John Rich
John Rich is offline   Reply
