neoscene quality differances? at DVinfo.net
CineForm Software Showcase
Old April 18th, 2009, 11:27 PM   #1
When choosing conversion quality settings, what is really happening to the files besides the size difference? are they all 4:2:2? at first glance they seam visually very similar .
on high my file became 707mb
on medium it was 532mb
on ow it was 432mb
what is are the advantages of using low over high, or med over high, why not high all the time?
thanks for the explanation.
john h
John Harvey is offline   Reply With Quote
Old April 18th, 2009, 11:35 PM   #2
John, higher bitrates generally correspond with higher quality, but it also means the files are bigger. ou will probably want to use either Medium or High. Ultimately it is your choice, and a function of how much you "push" your images in post. If you don't push your images too much then Medium might be perfect for you. For more extreme post corrections you might want to go with High.
Perhaps others might have some comments about the settings they use?
David Taylor is offline   Reply With Quote
Old April 18th, 2009, 11:53 PM   #3
Would low be a way of reducing the load on my older PC? kind of like a lower res proxy would do if I had that option?
jh
PS: thanks for the quick reply!
Old April 19th, 2009, 12:31 AM   #4
Yes John, lower data rates (Low setting) also lowers the compute load making processing more friendly for a tired PC.
Old April 20th, 2009, 03:52 PM   #5
David,
I wondered about these settings too.
does putting it on medium actually degrade your picture or just change a bit rate???
I run it on high for obvious reasons because I didn't I did not know for certain.
DATS ALL FOLKS
Dale W. Guthormsen
Old April 22nd, 2009, 11:58 AM   #6
Doesn't lower bit rate = lower quality by definition?
Bill Binder is offline   Reply With Quote
Old April 22nd, 2009, 02:52 PM   #7
See Cineform's new Web site for a nice write-up on the quality settings: Cineform Tech Blog Blog Archive Understanding CineForm Quality Settings. I'm digging the techblogs Web site...
Matt
Matt Vanecek is offline   Reply
