April 23rd, 2009, 05:25 PM | #1 |
Prospect HD color correction Crash
Hi I was wonding if anyone has had PPCS3 crash when you drop CF color correction or Levels on the video clip in the time line. CLips were captured using CF HDV Capture and the project was created using CF project. As soon as I drop the color or Leves correction on the video clip CS3 shuts down.
Using Vista ultimate fresh install of everyting OS CS3 brand noew system. Thanks |
April 23rd, 2009, 05:42 PM | #2 |
CTO, CineForm Inc.
What version of Prospect HD?
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
April 23rd, 2009, 06:42 PM | #3 |
V3.4.9
Thanks |
April 23rd, 2009, 06:55 PM | #4 |
CTO, CineForm Inc.
That should work fine, I was using that very feature without issue at NAB, those components haven't changed in a long time.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman Last edited by David Newman; April 23rd, 2009 at 09:58 PM. |
April 23rd, 2009, 09:09 PM | #5 |
Yup - I have that problem too.
http://www.dvinfo.net/conf/cineform-...n-filters.html (I admit I havent gotten around to filing a trouble ticket.... at the time I thought Version 4 would be out any day and I'd wait to see if that fixed the problem. Presently I simply avoid those filters) |
April 23rd, 2009, 10:50 PM | #6 |
CTO, CineForm Inc.
tell about you clip type, res. frame rate etc.
April 24th, 2009, 03:31 AM | #7 |
Hi Guys,
The clip was captures using CF thu PPcs3 No reszing and no conversion. Medium Quality. The rez is 1440x1080i 60i avi 29.97fps about 40 min long it a wedding ceromony. When I drop the clip into the time line ( only that clip) and try to add color correction or levels as soon as I drop it on the time line it closes. |
April 24th, 2009, 11:09 AM | #8 |
My problem is with the exact same type of footage: 1440x1080 60i CFHD files from ProspectHD 3.4.9 with CS3.2.0
32-bit filters crash CS3, 16-bit filters work fine. Last edited by Graham Hickling; April 24th, 2009 at 11:15 PM. |
April 24th, 2009, 02:01 PM | #9 |
Same here, with the 32 bit filters; except my footage is 50i
