Neoscene & CS4 1080p project presets at DVinfo.net
CineForm Software Showcase
Old May 23rd, 2009, 11:50 PM   #1
Can someone recommend the proper project settings for NEOscene processed files in Premier pro CS4?
It's a bit confusing as to which video preset is best of all the 1080p ones available.
jh
John Harvey is offline   Reply With Quote
Old May 25th, 2009, 10:57 AM   #2
John, check out this Tech Note posted on our Tech Blog: Cineform Tech Blog Blog Archive Setting up Project and Sequence Settings in Adobe Premiere Pro CS4 (Windows)
Alternatively you can go to the main Tech Blog page and search on CS4 which is exactly what I did to fine the Tech Note. http://techblog.cineform.com/
David Taylor is offline   Reply With Quote
Old May 26th, 2009, 08:26 PM   #3
THAT 'S HELPFUL, THANK YOU.
The Canon mk2 5d footage, for display, is that considered 30fps drop frame or non drop frame??
jh
Old May 26th, 2009, 09:27 PM   #4
CTO, CineForm Inc.
Non-drop and drop timecodes are terms that really only make sense at 29.97 -- non-drop is timecode at 30.0, means it is really running a tad slow, and "drop" the timecode skips two frames every minute (but not every 10 minute) to catch up with reality. At 30 you just have timecode (pick non-drop), not that anyone really using 30.0 timecode.
Old May 26th, 2009, 11:44 PM   #5
David,
Your answer was somewhat confusing.
the files coming from 5DM2 (.MOV) are coded as 30.000 fps, while the CineForm files (.AVI) are coded with 29.970. This tells me that Canon is using non-drop frames timecode, and when converted with CineForm, the files are then converted to drop-frame timecoed.
Is this correct? Is Canon actually using a non-drop frame timecode? (30fps) Or is that a mistake and the timecode is really 29.97fps?
Rick C.
Rick Casillas is offline   Reply With Quote
Old May 27th, 2009, 09:19 AM   #6
CTO, CineForm Inc.
No, but drop frame is confusing. More info : SMPTE time code - Wikipedia, the free encyclopedia
Old May 27th, 2009, 10:11 PM   #7
Ok, I guess you mean to say that Canon uses 29.97 fps timecode. Which in fact is coded with drop-frames. Even though they code a value of 30 fps in the .mov file.
Old May 27th, 2009, 10:53 PM   #8
CTO, CineForm Inc.
Not saying that either. Timecode is much simpler than you make out to be. The frames go from 0 to 29, and there is no skip at the 1 minute boundary (that word be drop frame), so it is non-drop by elimination. But 30.0 would never be drop-frame, just as 25.0 wouldn't be, noe is there for 24 or even 23.976, it only exists for 29.97 to make our NTSC based lives a little bit harder. :)
Old May 27th, 2009, 11:30 PM   #9
Ok going back to my original statement; canon uses 30.0 but when cineform converts to intemediate, the files are coded with 29.97 fps. Can you explain this phenomena a bit. That is where the confusion is.
Thanks David.
Old May 28th, 2009, 09:22 AM   #10
CTO, CineForm Inc.
But that has no impact on timecode. 95% on video tools and 100% of NTSC DVD needs to be at 29.97, so we made life a little easier using the Canon 5D.
Old May 28th, 2009, 03:22 PM   #11
So I guess the final answer is to choose 29.97 drop frame when rendering to maintain the playback to real time???
jh
Old May 28th, 2009, 03:36 PM   #12
CTO, CineForm Inc.
No. It is non-drop, unless you don't want timecode, by just what a "real" time playback position (maybe handy if your are doing a sit-com.)
Old May 28th, 2009, 03:53 PM   #13
David,
I understood that 30fps was non-drop and 29.97 was drop frame, however, in practice 29.97 can be both drop and non-drop, and I know that 30fps has always been non-drop.
And Cineform intermediates are coded as 29.97 but the timecode remains the same as non-drop frame.
Is this correct?
