Folder Problem while coverting clip with HDlink at DVinfo.net
CineForm Software Showcase
Old July 24th, 2009, 08:55 AM   #1
I'm converting clips with HDlink, but it keeps converting clip to same folder original clips are from even if I selected another folder in the "select folder" menu.
If I uncheck Overwrite existing files it won't convert claiming that files already exist but I I leave it unchecked it will add 001 at the end of original clip name.
How to set it up so that I convert directly with same name as original clip to another pre-selected folder ?
Thank you.
Sincerely,
Frédéric Leclair
Frederic Leclair is offline   Reply With Quote
Old July 24th, 2009, 07:04 PM   #2
"Select Folder" is to direct HDLink to the folder containing the files you want to convert.
To select the output folder for the converted files you need to access the "Prefs" dialog screen. Click on "Prefs" in lower right corner of HDLink. All of the important conversion parameters are in the Prefs section as well.
Bob
Old July 24th, 2009, 08:28 PM   #3
I didn't have have 'use capture folder for converted files' checked.... so my capture folder wasn't "active"...
Old July 25th, 2009, 01:01 AM   #4
Been there, done that.
Always a joy to have a simple solution!
Bob
Robert Young is offline   Reply
